10-03-2018, 01:19 PM | #89 |
Rep 931
Its the target that drops when they had the issue. Your actual boost actually goes somewhat over target, did you look at your log? I honeslty don’t think I see the issue we talk about here in your run.
10-03-2018, 01:47 PM | #91 |
Rep 2,653
10-03-2018, 03:00 PM | #92 |
Rep 1,105
10-11-2018, 06:00 PM | #95 |
Car Hypochondriac
335
Rep 901
So xhp just posted a short essay on their facebook page regarding ecu tuners fooling the transmission to get around the torque limits... Thought I would post the relevant bits here:
"The common workaround for tunes to operate properly and not hit torque limits, is to "bend" the torque calculation in the ECU, so it well never calculate a value above the transmissions stock limits. Problem solved? Well, not really. Given what's said above, the trans will now operate with wrong clutch pressures. The torque calculation is calibrated to match real world torque very closely. If you alter this calculation, you create an offset between calculated and real world torque, which directly triggers the transmission to operate with too low line pressure." "Short term you may feel that shifting is sometimes a bit off, delayed or not as crisp as it should be. Long term this will lead to extended clutch wear as there is more slip on every shift and even in gear. (Microslip) Adapting the torque limits and using a tune with proper torque calculation will avoid all that AND will increase holding power of your transmission dramatically! Especially important for people with upgraded Turbos, which are pushing the limits of their platform. The ZF transmissions are incredibly well built and can last forever, even when operated well above stock torque, as long as they are adjusted properly. For our upcoming 8HP solution, people will be able to chose between a standard map, which keeps 90% stock behaviour but has the torque nannys adjusted, or go for the full solution with a lot of features added. Stay tuned for more info the next weeks!" |
10-11-2018, 07:07 PM | #96 | |
Rep 2,653
10-12-2018, 11:40 AM | #97 | |
Rep 525
10-12-2018, 02:21 PM | #98 |
Rep 1,105
Always better to ask for clarification!
10-13-2018, 07:59 AM | #99 |
Mike: Everyone's Pal
2042
Rep 2,972
Drives: F80 M3
I hope they set the shift points to right before the PWG turbo starts to tail off.
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix |
10-13-2018, 07:14 PM | #100 |
Rep 16
10-13-2018, 10:48 PM | #101 | |
Rep 546
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
12-25-2018, 04:34 PM | #103 |
Car Hypochondriac
335
Rep 901
12-25-2018, 08:17 PM | #104 |
Rep 2,653
I don't see it as being available either.
12-25-2018, 09:44 PM | #105 |
2042
Rep 2,972
Drives: F80 M3
12-25-2018, 11:42 PM | #106 |
Rep 470
He's in germany, might have been released there?
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
12-26-2018, 12:06 AM | #107 |
Rep 1,693
12-26-2018, 01:54 AM | #108 |
Rep 504
12-26-2018, 02:18 AM | #109 |
Rep 7
12-26-2018, 02:23 AM | #110 |
Rep 7
