BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Comparison: X-Drive vs. RWD Suspension
European Auto Source (EAS)
      07-29-2013, 09:15 PM   #1
MrMikeHenry
Drives: 2011 E93 m3
Im still confused as to why X-Drive models cannot use RWD coilovers or springs and vise versa here is a side by side comparison of the spring and shock components everything looks identical to me.
Anyone want to chime in?
I cant find any reasonable explanation even on the e90 forums.
      07-29-2013, 11:19 PM   #2
slmdgee
Usofstance
Drives: 328I 6SPD
why because the front has axles..... The rears are the same but the fronts are completely different.
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      07-30-2013, 10:02 AM   #3
MrMikeHenry
Drives: 2011 E93 m3
but what does that have to do with the struts and springs? Only thing you can change with a spring is the height , diameter , and spring rate. Clearly the height and diameter is the same on both models so I still cant see why coilovers wouldnt be compatible.
coilover, shock, spring, suspension, xdrive
