06-03-2018, 03:58 AM | #23 | ||
Rep 1,863
06-03-2018, 04:00 AM | #24 | |
Rep 11,292
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
Soul_Glo13347.00 |
06-03-2018, 06:11 AM | #25 | |
Rep 1,705
It doesn't matter what test you do with the key. See its article that's says some equipment can pick up the signal from 100 metres away. https://www.contracthireandleasing.c...-you-avoid-it/ Last edited by sensible; 06-03-2018 at 06:17 AM.. |
Malone289.50 |
06-03-2018, 11:02 AM | #26 | |
Rep 1,863
JustChris17487.50 |
06-03-2018, 11:35 AM | #27 | |
Rep 1,705
However, the point I am making is that your tests with your key are pointless. Just because your key ha's a one metre range doesn't mean a scanner couldn't pick it up at a range of more than one metre. Last edited by sensible; 06-04-2018 at 01:44 PM.. |
06-03-2018, 12:19 PM | #28 | |
Rep 2,192
M3 CP in THE fastest colour (says so in the title )
dopper993531.00 |
06-03-2018, 05:13 PM | #29 |
Rep 11,292
06-03-2018, 11:12 PM | #30 | ||
Rep 7,484
Solution? Faraday bag. Manufacturers solution? Comfort access keys need to time out rather than always be on. May be a button sequence could help by turning the key off until next use required - or a simple off switch. Lazy owners would complain though. It would be a matter of time before someone forgot to turn the key off and insurance problems would arise. The locking systems also need a higher bit encryption. BMW's hi-tag system has around 48 codes. 128-256 bit end to end encryption is required with full use of the millions of combinations. A 256 bit encryption would take more than 21 years to decrypt. Think of RSA tokens if you have ever logged on to a secure server. The RSA key is an added layer of security. With one RSA key (the one with LCD) reader costing upwards of 800 imagine losing a key. Manufacturers should have this as an installation option for the security minded. Without a physical RSA key present and the code could not be entered or scanned. Scanning would be nice to save destroying radio preset buttons. People who own a Ghost already enter a pin sequence anyway. |
06-04-2018, 02:43 AM | #31 |
Rep 13,043
Drives: BMW M340I G20
What about an old sweet tin? £4 when full and you get to eat the sweets. Win Win.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
Soul_Glo13347.00 |
06-04-2018, 02:51 AM | #32 | |
Rep 6,945
06-04-2018, 01:41 PM | #33 |
Rep 1,705
Try it to make sure. I initially put the wife's Renault key in an M&M tin. I took it out to the car and the car opened. I then tried a Worther's Original tin and that one worked. No idea why one worked and the other didn't.
Soul_Glo13347.00 |
06-05-2018, 02:00 AM | #34 |
Rep 13,043
Good old Werthers
