11-15-2014, 05:43 PM | #23 |
Infidel
122
Rep 1,102
This answers is just...
11-17-2014, 08:44 AM | #25 |
Rep 1,366
If you have adaptive M suspension you have EDC. My understanding is that DHP is adjust on the fly while adaptive M is set it and forget it much like the Bilstein B16, yes, the same B16 from over 10 years ago. If adaptive m didn't have EDC then the Dinan shockwave software update and Dinan's description would all be a waste. See www.dinancars.com for a description.
11-17-2014, 01:31 PM | #26 |
Rep 28
Just to clear this up, my question was related to how (if at all) cars without DHP (or just M Adaptive Suspension) alter the suspension when changing the Driving Mode from Comfort to Sport/+.
Apparently they don't, since it's a static suspension regardless of being stock or M Sport (704). Which makes sense, but contradicted what sales advisors told me when I was test driving. In hindsight I should have asked them how that was possible without electronic dampers, but didn't think about it at the time. I had read about and wanted DHP anyway. |
11-17-2014, 05:17 PM | #27 | |
Rep 1,503
12-10-2014, 06:33 PM | #28 |
Rep 5,056
Ok hate the resurrect this thread but I just took delivery of my 435GC without DHP and I have options to change chassis settings in iDrive. Guess chassis in this situation just changes the steering stiffness
12-10-2014, 07:44 PM | #29 |
Rep 2,266
And throttle mapping.
F30 Sapphire Black M-Sport 335i 6MT
12-10-2014, 08:00 PM | #30 | |
Rep 2,290
When you configure "sport mode", which options show up? If it looks like this, then you have DHP. |
12-11-2014, 12:34 AM | #31 |
Rep 5,056
I do see those options in iDrive. However although I haven't actually looked at my shocks I am 100% certain I do not have DHP. Definitely did not order it, it's not on my spec sheet or VIN checker and I feel no difference in suspension between modes. I'm guessing it just allows changing the throttle mapping and steering heft independently now. BMW should have made a separate button for the adjustable dampers. Like a button with a suspension element on it like Porsche does.
12-11-2014, 04:17 AM | #32 | |
Rep 15,858
Drivetrain changes the gearbox and throttle mapping in my experience. Others are stating it is linking the throttle to the chassis setting, is this a new combination for 4-series models and later 3-series productions? It was not the original combination, or listed as such in BMW data. For the 3 and 5-series (and other ranges) BMW definitely have Drivetrain changing the shift program and throttle mapping; Chassis, the steering and damping (if fitted). HighlandPete |
12-11-2014, 04:21 AM | #33 |
Rep 15,858
12-11-2014, 04:26 AM | #34 | |
Rep 15,858
HighlandPete |
12-11-2014, 07:58 AM | #35 | |
Rep 1,086
2016 M3, Mineral White, SO Leather, MANUAL - ED 11/26/2015
2013 335i, Blue, M-Sport, Auto w/Sport Trans - ED 06/10/2013 |
12-11-2014, 08:27 AM | #36 |
Rep 516
When I test drove a non-DHP car and put it in sport mode I could have sworn the whole car stiffened up. But looking back, Im pretty sure it just the transmission dropping a gear and giving me engine braking.
12-11-2014, 10:15 AM | #37 | |||
Rep 2,290
I seriously hate the way BMW fragments options from year to year, and then makes it more complicated through terrible iDrive implementation. It's unnecessarily confusing. |
12-11-2014, 10:45 AM | #38 | |
Rep 4,856
12-11-2014, 01:28 PM | #40 |
Rep 213
YOu are wrong. When changing to sports mode, the steering, drivetrain and suspension tightens up. You know how I know you are wrong!?! Because I drive one...put on sports mode and the suspension changes and has no body roll while driving. Please educate your self before you give an idiot answer and change someone's opinion. Not because you sound confident makes you right.
12-11-2014, 01:30 PM | #41 | |
Rep 213
12-11-2014, 01:54 PM | #42 | |
Rep 1,003
Drives: 16 340i, 15 X3d, 91 318i
Please refer to the BMW University Technical Training Manual for the F30 Chassis, which can be found here: http://prodcds.bmwuniversity.com/lib...20Dynamics.pdf Section 3.3 clearly states that conventional shock absorbers are standard. (No EDC!) Option code 704 (M Sports Suspension) provides tighter spring/damper (and a 10mm lower ride height for RWD). (No EDC!) Option code 2VF (Adaptive M Sports Suspension) is the electronically controlled damper system (and a 10mm lower ride height for RWD). This option is part of the Dynamic Handling Package, aka "DHP". Section 6 talks about the Driving Experience button, the rocker from Eco Pro to Comfort to Sport (and Sport+ if you have one of the requisite options listed). All cars have it. All cars will have a menu in iDrive to configure "Chassis" settings for each mode. If you have 2VF (which, again, comes with DHP) then your Chassis setting applies to the dampers. If you do NOT have 2VF, then your Chassis setting applies to only the steering and DSC (traction control). Option code 2VL, Variable Sport Steering (aka "VSS"), is the other part of DHP. The difference with VSS is that the rack is faster as you steer away from center. With or without VSS, Sport mode increases steering weight. I had to put my 2 cents in, maybe this will add some clarity and at least people can take a look at the technical literature. Want to know exactly which option codes were installed on your car? Get the last 7 of your VIN and go here: http://www.bmwarchive.org/vin/bmw-vin-decoder.html Last edited by S4NoMore; 12-11-2014 at 02:06 PM.. |
12-11-2014, 02:37 PM | #44 | |
Rep 4,856
Have you driven both? DHP vs non DHP?? There's a noticeable difference when you: 1) hit a bump. 2) tight turns. |
