07-08-2019, 05:07 PM | #1 |
Rep 438
Drives: F30 335i M Sport
10.25 iDrive Screen
10.25 idrive screen from F15 X5. Used condition. No cracks or scratches to the screen. Pictures of it being tested in F30 335i with NBT evo. Last edited by xxxjecxxx2; 10-16-2019 at 12:33 PM.. Reason: item damaged, no longer for sale. |
07-11-2019, 03:20 PM | #2 |
Rep 765
07-11-2019, 06:05 PM | #3 |
Rep 438
07-12-2019, 05:01 PM | #5 |
Rep 438
This screen operates on the APIX1 protocol which will may need to be coded if your NBT / NBT EVO doesn't already use it. But all NBT units support APIX1.
The coding required on the NBT or NBT EVO is: CID_APIX_Mode > apix1 CID_COLOR_DEPTH > 24 CID_COM_MODE > spi CID_DISPLAY_RES > 1280_480 CID_DISPLAY_SIZE > 10_25 |
07-14-2019, 07:36 PM | #6 | |
Rep 1,493
Thank you. I’ll send you a PM shortly. |
xxxjecxxx2153.00 |
07-16-2019, 06:55 AM | #7 |
Rep 438
Including free usps priority shipping inside the US. Delivery in 2-3 days.
07-16-2019, 08:54 PM | #8 |
Rep 438
Also price drop.
07-20-2019, 09:08 AM | #10 |
Rep 438
07-20-2019, 09:25 AM | #11 |
Rep 1,067
How about the mounting holes / screw attachments though? Sorry, I've been trying to find a DIY that isn't the "finished product", but one that shows how to do it. Main reason for selling?
07-20-2019, 01:39 PM | #12 |
Rep 145
what's the main reason for selling? Also i have a 2015 328i with nav, so basically an nbt...so what can I expect..just a bigger screen or any other other functionality as well?
07-20-2019, 08:26 PM | #13 | ||
Rep 438
As I took the pictures, I realized that I did modify some parts a bit to fit. My car is 2013 so early model probably has different dashboards then newer cars. I also had to get a voltage converter 12v to 9v because I have NBT EVO retrofit. If your car is not 2017, you probably don't need it. By no means a tutorial but to fit this screen into F30, you have to remove the two tabs that are circled in red (already removed). The screen for sale has these OEM tabs there. They break off very easily with pliers. Installed in my F30. Sorry it's dark I used different screws because I prefer the Phillips screws but it uses the same mounting holes.
08-03-2019, 09:23 PM | #14 |
Rep 438
To the top, price drop.
08-06-2019, 08:07 PM | #16 |
Rep 438
08-07-2019, 06:22 PM | #18 |
Rep 438
09-30-2019, 06:48 AM | #19 |
Rep 438
To the top. Still available
10-15-2019, 01:55 AM | #20 |
Rep 438
Lower price
10-15-2019, 10:00 PM | #21 |
Rep 20
Drives: F30/N55
Sold!
