BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25" Android 9.0 HU discussion
      11-09-2019, 05:31 PM   #1057
marakeh
Drives: BMW 118D
Originally Posted by QUiKSR20 View Post
Anyone else have an issue where it just doesnt keep the correct time? Any tricks?
Ive tried "Android Time", Ive tried "iDrive Time" no matter what combination it either always goes back to the 24HR clock or the wrong time after the car is shutdown and restarted.
with root, you can try to modify the build.prop for your timezone, alternative, use original time (will get the time from the car clock through can)
      11-09-2019, 06:39 PM   #1058
QUiKSR20
QUiKSR20's Avatar
Drives: 13' F30 328i 6MT
Hello Marakeh, Appreciate your input.... Thats what I mentioned though, Ive set it to "CAR TIME" ie CANBUS it still either puts itself back in 24hour mode or the wrong time.
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread
89 E30 325is [sold & missed]
      11-10-2019, 04:34 AM   #1059
marakeh
Drives: BMW 118D
i had the issue too, i unchecked all the time check boxes, did a reboot through the system settings, enabled original time, did a reboot and after that the unit applied the car clock directly after boot.
      11-10-2019, 04:54 AM   #1060
QUiKSR20
QUiKSR20's Avatar
Cool ill give that a try, thank u
      11-10-2019, 05:57 AM   #1061
mrsimes
well, before removing the caps it would be easier to just unplug the aux port in the armrest
It's the Android unit that's blowing the sound out though because if I plug anything else into AUX it is perfectly clear. I just got unlucky with a crap unit.
      11-10-2019, 11:00 AM   #1062
twoface
Drives: BMW 316D
How do you report bugs or feature requests? Seller doesn't really respond to my requests. There is app called "User feedback" but its one way communication.
Its really annoying me that all apps in Android will close if I switch to idrive and then Android again. I bought Tasker app in order to try to solve it but I'm a noob for it.
      11-10-2019, 11:07 AM   #1063
Kri
Austria
1084
Drives: E87
The only way to report bugs is to write your seller.
They normally do not listen to feature requests.
Chri
      11-11-2019, 02:29 PM   #1064
Xanderl
How can i Open the Back rear View? I have a Wireless Camera But my Snapdragon didnt Turn on the Back up View (manual shift gear)
      11-11-2019, 04:16 PM   #1065
Spanielgita
Drives: BMW 335D F31 2015
Hello to all, I have installed a 10.25" android 9.0 headunit and would like to warn everyone reading this of the dangers of not routing your cables carefully behind said unit.
After reinstalling my headunit there was a bit of a struggle to get it back in the recess. I may have pushed a bit too hard and one of my connectors has unfortunately snapped off. I am now in a position were my headunit does not seem to power up at all and I have a connector to fix of which I may struggle to source the new part.
Here are some pictures of my plight. Please don't be as foolish as me.
      11-11-2019, 04:29 PM   #1066
QUiKSR20
QUiKSR20's Avatar
Has anyone successfully paired an OBD Dongle such as veepeak's OBD dongle to these Snapdragon head-units. I wanted to setup a dash app like Torque or RealDash?
      11-11-2019, 05:36 PM   #1067
Kri
Austria
1084
Drives: E87
Bluetooth does only work with Smartphones / Phone Music app, not other stuff.
If you want to use a ODB Dongle you need to user either a USB or Wirless LAN Interface.
Kri
      11-11-2019, 05:48 PM   #1068
Gabrielisimous
Gabrielisimous's Avatar
Drives: F30 328i 2013, E46 325i 2005
Anyone who can help I have installed Avinusa 10.25 PX6 head unit and also installed an aftermarket reverse camera but when switching to "P" from "R" it takes about 5 secs to switch back to the normal screen, thank you in advance
Gabo
      11-11-2019, 05:56 PM   #1069
Gabrielisimous
I did the following
Go to "time" and put manually the time and date then check original time, after this go to "more settings" Date & Time (this is on Android kind of settings) set the correct time zone for your area (default it wills how "China")now your clock should be set and remembered each time your unit restarts
Gabo
      11-11-2019, 11:25 PM   #1070
QUiKSR20
QUiKSR20's Avatar
Kri
That stinks but good to know, I just purchased a Veepeak OBD Dongle that looks like I wont be able to use it outside of Bimmercode & other apps.
Originally Posted by Gabrielisimous View Post
I did the following
Cool thanks ill try this as well, I think I got the time to stick somehow but it keeps going to 24hr
      11-12-2019, 08:00 AM   #1071
Spanielgita
Just an update in case anyone else does similar, turned out I had blown a 20 AMP fuse, number 121 (for the headunit) located in the boot fuse box. Replaced this and the headunit came back to life, albeit with no FM radio reception now. Not an issue for me as I use DAB.
I re-installed my screen with the negative off the battery and made sure to route the cables better so I wasn't likely to break anything again. So far so good, all working again. I am well pleased!
      11-12-2019, 08:48 AM   #1072
Mjam
Drives: E87, i3, Taycan Cross Turismo
Look for Gear Selection in the Factory Settings, Vehicle, it works like this:
Automatic: The red Camera Power cable should be getting power when in reverse gear. Measure with a voltmeter. If so, this is where you should connect the power cable to the camera.
Manual: If Automatic doesn't work, you must manually tell the Android unit when in reverse gear. To do this, power the purple DET cable (detect).
      11-12-2019, 09:14 AM   #1073
Mjam
After a few weeks experience, I have three main problems with my Snapdragon unit (E87, 2009, M-ASK Business Navi).
1. PDC doesn't work. This is a major issue. I've tried everything. MCU and App upgraded to 3.0.8. PDC is just not getting power when CAN cable is connected to the Android unit. Disconnect CAN1 and it lights up (but then Android shuts down without CAN connection). I even tried powering the Detect cable, the camera interface is triggered then, and it shows the PDC graphics, but it doesn't work. Android must be interpreting CAN signals wrong?
2. The unit is powering off after only ten seconds when the key is removed, and does a full boot when key is re-inserted. The normal behavior is that it goes to sleep for about 5 minutes before powering off?
3. Like others I experience problem with sound from Navi apps if the built in music player is not started first: Full volume from front left speaker. When music player is started first, music is muted and Navi commands (Waze) are transmitted though all speakers, in a pleasant voice and volume.
      11-12-2019, 10:24 AM   #1074
Kri
Austria
1084
Drives: E87
does PDC not work at all, also no beeping ? or does it just show no picture / signal ?
Does it work when you are at the original Display screen?
PDC-ECU and the Button at the center console are not directly connected to CAN directly, and not to the HU directly.
This is a normal behavior of the Snapdragon HU, it does shut down after 10-30 seconds and not changeable at the moment.
Kri
      11-12-2019, 10:55 AM   #1075
Joe111
Drives: F30 320D
I recently purchased the andriod screen from Avin and I have just completed the install. Everything seems to be working properly apart from the GPS.
The only problem I'm having is with the unit no being able to lock onto a satellite, so at the moment the navigation side of things is not working. I placed the GPS receiver on top on the glove box under the dash.
My car had the 6.5inch screen with no nav.
Any advise or tips from anyone?
      11-12-2019, 10:57 AM   #1076
grocerylist
Drives: BMW M235i
2016 BMW M235i  [0.00]
Has anyone tried the new Android Auto for phone screens app that was released about 2 weeks ago? Wondering how or if this works and entirely eliminates the need to physically connect an android phone via USB to the head unit display?
      11-12-2019, 11:17 AM   #1077
seaman5705
Drives: BMW F10
headunit internals
I have opened my Snapdragon unit, due to my problem (stuck at fastboot), in search for OTG resistor .
I have the unit with external box, from Andream . I am posting pictures of the board which is hosted by external box. Processor, auxiliaries and connections are in this box, display contains only LCD with touch and controllers .
If anyone wants more detailed pictures or is curious about something , I am ready to help , while the unit is on the table.
So far I could not identify any resistor marked as OTG . Only a strange golden one (marked as "b" or something , in red circle).
      11-12-2019, 11:36 AM   #1078
Xanderl
Where i can get the newest updates for Android headunits? 🙈 have a avinusa Snapdragon 625 headunit
