02-10-2015, 12:56 PM | #134 | |
Rep 5,316
Drives: G80 M3 6MT
Try that and let me know if it works. Its in FEM_BODY
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
02-10-2015, 01:52 PM | #135 | |
Rep 42
Should it be aktiv or nicht_aktiv? I found out that this parameter is only for parking light position, not the 0-position.. Another way to do this is to make the parking light to be as strong as the DRL Last edited by HPVL; 02-10-2015 at 01:59 PM.. |
02-10-2015, 01:54 PM | #136 | |
Rep 5,316
Drives: G80 M3 6MT
Did it work?
Scott, Partner
02-10-2015, 02:13 PM | #137 |
Rep 42
02-10-2015, 02:19 PM | #138 | |
Rep 5,316
Drives: G80 M3 6MT
Which specifically do you want to use your fogs with?
Scott, Partner
02-10-2015, 02:30 PM | #139 |
Rep 42
02-10-2015, 02:49 PM | #140 |
Rep 5,316
Drives: G80 M3 6MT
You can't use fogs with the 0. Put it in parking light mode, thats DRL only and you can use fogs.
Scott, Partner
02-10-2015, 02:51 PM | #141 |
Rep 42
02-10-2015, 02:53 PM | #142 |
Rep 5,316
Drives: G80 M3 6MT
I don't think that's the case. It isn't on my car. I'm pretty sure the only time they dim are when the headlights are on.
Scott, Partner
02-10-2015, 02:58 PM | #143 | |
Rep 42
FEM_BODY 3062 MAPPING_PARKL_V_L_PWM_LEVEL_1 32 8 Change Parking Light Brightness (Left) FEM_BODY 3062 MAPPING_PARKL_V_R_PWM_LEVEL_1 32 8 Change Parking Light Brightness (Right) Can you check your values please? |
02-10-2015, 03:01 PM | #144 |
Rep 5,316
Drives: G80 M3 6MT
When I get home I will if I have time tonight.
Scott, Partner
02-10-2015, 03:05 PM | #145 |
Rep 5,316
Drives: G80 M3 6MT
You can also just try changing it to 32 as the guide suggests, for some reason I really thought there was not a brightness difference. Actually, are you sure that Daytime Running Lights is checked under Settings-->Lighting in your iDrive?
Scott, Partner
02-10-2015, 03:32 PM | #146 | |
Rep 42
Shows Day-Running Lights as option in iDrive Settings in Lighting: HU_NBT 3000 Daydriving_light aktiv standard Thanks a lot |
02-10-2015, 03:43 PM | #147 | |
Rep 5,316
Drives: G80 M3 6MT
Scott, Partner
02-10-2015, 03:48 PM | #148 |
Rep 42
That exactly what Im saying! This is a EU spec F32, maybe thats the reason behind all this struggle...
02-10-2015, 04:23 PM | #150 | |
Rep 42
FEM_BODY -> 3060 -> TFL_MODUS: Tfl_s -> DRL in A and 0 position Drl_s -> DRL in A, 0 and 1 position Off -> DRL off Mine is set to Tfl_s, Im pretty sure, yours set to Drl_s. Can you please confirm this when you get home? Thanks in advance |
02-11-2015, 01:30 AM | #151 |
Rep 5,262
should be 64 not 32 as 0x64 = 100
02-11-2015, 01:32 AM | #152 |
Rep 5,262
I think all US cars are drl_s
02-11-2015, 06:18 AM | #153 |
Rep 5,316
Drives: G80 M3 6MT
I'm going to look this morning before work. Will report back.
Scott, Partner
02-11-2015, 11:35 AM | #154 | |
Rep 5,316
Drives: G80 M3 6MT
Yup, go ahead and change it to DRL_S and see if that solves your parking light brightness issue, should do. Let us know.
Scott, Partner
