02-06-2020, 12:01 PM | #23 | |
Rep 34
06-07-2021, 06:10 PM | #24 | |
Rep 5
The harness is to route power from the working side to the bad side
06-07-2021, 06:22 PM | #25 |
Rep 5
Any one tried using a relay for the HID
I think i am gonna try to use a relay to power the HID too see if the car will accept. I had the same issue, after using HID on my 2014 328I my right low beam went out. Check with multi meter and only about 5v was coming out. All other lights worked fine and i tested the OEM wiring harness for any faults and routed power from another source and it worked fine. It was the Front Electric Module\footwell Module. For some reason it was not pushing power to the right low beam. The Part cost $800 not costing labor and must be installed by BMW because it requires coding. Unless you find someone with the $3000 computer to recode a FEM, BMW are usually the only ones that can do it. I Think something melted on the FEM or the Junction wire connected to it. I will look at those next.
