03-05-2020, 09:09 AM | #1 |
Rep 40
N20 Valve Cover Gasket DIY, some useful tips...
Posting these to help fellow DIYers. I have done VCGs on all the bimmers I have had E30, E46, E92, E84. The reality is that the complexity of this job has increased with the newer engines. It took me about 6 hours. Forums report that Indies (2020 pricing) can do this job for $500-700 labor plus parts. If you get the VCG kit (includes new cover, bolts and seals) plus the eccentric shaft seal, parts only will set you back about $280 shipped.
This won't be a step by step DIY but will point to key areas and provide links to other resources. All together it should provide a fairly good guide.
BMW CCA 475714
04-11-2021, 01:10 PM | #2 |
Rep 7
Appreciate the tips. Mine just started leaking and the indie wanted $1100 for the job (whole valve cover, not just the gasket), so I'll be giving this a shot myself.
06-18-2021, 07:13 PM | #3 |
Not stock
472
Rep 617
Just did this job today. It sucked compared to my M5x/S5x engines. Protip... The low pressure fuel supply pipe... Watch that the flare nut doesn't work its way down the firewall. If you don't realize that the low pressure nut is not up bear the valve cover it's especially not fun to work it up and requires loosening/removing the plastic cable/O2 bracket from the rear of the head/VC which also sucks. I can see why the dealer and Indy charge so much. Glad I did it as I now understand how terrible it is compared to previous engines.
Bad news: After about 60 mile round trip we got home and the valve cover itself is oily above the head/cover joint, so it must be a crack some place. I don't see oil atop of the valve cover, so it must be in the side or around the bolt hole, etc. Sigh - now I need to source a valve cover and get this project done all over again. Last edited by 5mall5nail5; 06-20-2021 at 09:14 AM.. |
RMachuca3d722.00 |
