05-29-2022, 01:48 PM | #2356 |
Rep 1,010
Start with adding 2 gallons of Ethanol on a full tank and also you can run Stage 2 93 oct tune by adding 3 gallons of Ethanol.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
05-31-2022, 12:49 PM | #2357 |
Rep 950
You're in vegas! People have ethanol there just look up local car enthusiast groups and buy some from them. I also thought I didn't have access to ethanol but then I went on fb and found car guys and now I buy ethanol out of some guys garage
05-31-2022, 06:59 PM | #2358 |
Rep 554
Trying out E for the first time (more than just a gallon to clean up timing) Stage 2 E30 BM3 with AA DP and TU pump. Mixed it up to about E35 to be on the safe side. How does it look, especially the STFT?
https://www.bootmod3.net/log?id=6296...729b4203862612 I've got the TU pump...what do they change for stage 2+? More timing and more boost?
2019 X3 M40i | TU Pump | AA DP | VTT GC | xHP Stage 2 | Dorch ECA | MHD Odin FF | Carbon Black | Adaptive Suspension | M-Sport Rear Diff | 20" staggered
SOLD! 2015 X1 35i | Alpina Trans Tune | Dinan Stage 2 | Bilstein B6 |
06-01-2022, 08:41 AM | #2359 | |
Rep 1,010
Your stock turbo is the bottleneck, I think best way to go either a custom tune with low boost high timing or get a bigger turbo or both
abbike18701.00 |
06-01-2022, 09:02 AM | #2360 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
I have a 2019 Supra with just a catless DP and AMS intake manifold.
It's used at the track a fair bit on MHD Stage 2 E30 and goes really well. I logged some dyno runs today and was wondering if anyone thinks there's much to gain from getting a custom e40 tune? Logs https://datazap.me/u/nugs/dyno-runs-mhd-stage-2-e30-ots Dyno curve |
06-01-2022, 10:20 AM | #2361 |
Rep 44
Thank you , I'll check around. Have you actually check gas stations as well? I saw some forums dated 2020 that said we still had some e85 in town.
06-01-2022, 10:50 AM | #2362 | |
Rep 1,010
Sorry I don't like this log, HP peaks at 5500 RPM and then falls like a rock, Nugget It's better if you make a normal street log maybe the car is not liking the dyno.
Stage 2 HPFP E40 should give you around 21.5 psi boost and same 18 degrees timing. Quote:
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- Last edited by IMS-340C; 06-02-2022 at 05:21 AM.. |
06-02-2022, 05:14 AM | #2363 |
Rep 1,010
Adding HP to logs
This is really cool, I added HP to my logs :
https://datazap.me/u/ims/imshp?log=0&data=20-33 Anyone can do it easily with those simple steps: 1- Open csv file using Excel 2- Insert a new column and name it HP 3- Make this formula in the 1st HP cell: (1st cell in Torque Act. Clutch X 1st cell in RPM) / 7121 for NM or 5252 for LB-FT 4- Drag down the HP cell to repeat formula in all cells 5- Upload csv and now you will have HP in your log
mgeller51.50 |
06-02-2022, 09:26 AM | #2364 | |
Rep 950
https://datazap.me/u/wrxtobimmerguy/...g=0&data=11-66 |
06-02-2022, 10:08 AM | #2365 | |
Rep 1,010
Though we don't know how accurate it is in all tunes but it looks cool anyway
06-02-2022, 10:34 AM | #2366 |
Rep 950
06-02-2022, 10:41 AM | #2367 |
Rep 3,877
A dyno will not give you a clear answer how accurate it is, though. The exact, individual difference between clutch and wheel torque/power will always remain an unknown/assumption.
06-02-2022, 11:24 AM | #2368 |
Rep 1,010
560 HP with 25 psi boost and 13 deg timing not sure I think it's around 500-520 HP.
Why does your log include amb. pressure in boost calculation ? also please change units to psi
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- Last edited by IMS-340C; 06-02-2022 at 12:36 PM.. |
06-02-2022, 01:04 PM | #2369 |
Rep 950
My tuner prefers them to all be in metric. At my elevation I believe I'm at 26 psi of boost. But I won't know the true numbers until I dyno it. My tuner requested ambient in the boost calculation but you can subtract out the ambient to get the actual boost which I believe is 26 psi.
06-02-2022, 01:32 PM | #2370 | |
Rep 1,010
Yes correct 26 psi I was using a round figure.
Do you have a log with pure 850 and OTS tune ? Quote:
06-02-2022, 01:52 PM | #2371 |
Rep 950
I don't actually. I've never done a WOT with a pure850 and OTS. Is that something that would help you greatly or are you just curious because it would be an inconvenience to get it for you but if it will genuinely help you out I can do that for you.
06-02-2022, 02:13 PM | #2372 |
Rep 1,010
Was just curious thanks.
WrxToBeamerGuy492.00 abbike18701.00 |
06-02-2022, 04:16 PM | #2373 |
Rep 950
Another log from my newest revision done today. Increased timing to 16 deg.
https://datazap.me/u/wrxtobimmerguy/...v6?log=0&data= |
06-02-2022, 06:20 PM | #2374 |
Rep 554
I share this curiosity. All that talk about same boost pressure but upgraded turbos flowing more air at same psi. Would be cool to see logs actually comparing that.
06-02-2022, 08:09 PM | #2375 |
Rep 950
06-03-2022, 08:50 AM | #2376 | |
Rep 1,010
Looking very good what's your target from this setup ?
