04-12-2022, 04:25 PM | #3037 | |
Rep 5
04-12-2022, 11:07 PM | #3038 | ||||
Rep 9
Another newbie question. What is the difference in PSdZData_Lite and PSdZData_Full in regards to E-Sys operation (Lite for coding only and Full for programming)? Also, will PSdZData_Full allow for coding or do you need Lite as well? Basically, is there a need to have both packages and can those package versions deviate or will that cause issues? |
04-13-2022, 12:12 AM | #3039 | |
Rep 40,789
04-13-2022, 01:52 AM | #3040 |
Rep 16
shawnsheridan, e-brake doesn't work properly on my F01. There is no green CAFD in SVT for EMF module. Does it mean i need to flash it? And what is difference between Read SVT(VCM) and Read Ecu?
04-13-2022, 08:36 AM | #3041 | |
Rep 40,789
Connect => Read FA (VO) => Activate FA (VO) => Read (ECU) => Left-Click on EMF ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown (bottom one) => Select OK => Right-Click on EMF ECU (the ECU itself not the underlying CAFD) => Select CODE. Injecting CAFD (Detect CAF for SWE) and Flashing ECU's with >= v.4.17.20 PSdZData requires using newer E-Sys 3.30.0 or higher. Read ECU is a live query of all ECU on system busses. Read Read SVT reads a an ECU List stored in car VCM.
04-13-2022, 11:40 AM | #3042 |
Rep 332
To shawnsheridan,
Having just changed to Bimmer Utility I can't connect to the car. With E-Sys 3.27, with or without using Launcher 3.7.0.315, connection via VIN works every time. Changing to 3.38 or 3.39 (either should work with BU), I only get "No ZGW available", whether I use BU or just run E-Sys. In all cases the same PC and ENET cable. Do you have any suggestions, please. |
04-13-2022, 12:01 PM | #3043 | |
Rep 40,789
04-14-2022, 08:46 AM | #3044 |
Rep 332
A bit puzzling. I left it for a day and reinstalled E-Sys, and it now connects. BU seems more accurate than Launcher 3.7.0.315, as I can now find some FDL values for my F40 that seem to have been incorrectly labelled.
04-14-2022, 09:08 AM | #3045 | |
Rep 40,789
Yes, fixes some incorrect mappings and adds new mapping that was unmapped.
04-14-2022, 11:16 AM | #3046 |
Rep 332
Overall, much improved over the last Launcher, although it feels rather cumbersome in use. However, the NCD comparison is a welcome return! This really has to be the best option at present, while hoping they keep the mapping up-to-date.
04-14-2022, 01:51 PM | #3047 | |
Rep 16
04-14-2022, 02:32 PM | #3048 |
Rep 40,789
No, you need newer E-Sys. Injecting CAFD (Detect CAF for SWE) and Flashing ECU's with >= v.4.17.20 PSdZData requires using newer E-Sys 3.30.0 or higher.
04-14-2022, 02:47 PM | #3050 |
Rep 40,789
Your Receive PM function is disabled. PM me when working.
04-15-2022, 10:32 AM | #3052 |
Rep 40,789
04-17-2022, 03:17 AM | #3054 |
Rep 40,789
04-17-2022, 10:14 AM | #3056 |
Rep 40,789
04-18-2022, 09:39 AM | #3058 |
Rep 40,789
