BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 N55 sudden shake at idle and shaking on highway
      03-17-2024, 03:35 PM   #1
Andrew2512
Drives: 2015 BMW 335I
Hi guys,
I had a bad plug a month ago, cyclinder 2, but I replaced all of them with Bosch OEM, I also found out that my #4 coil was also broken so replaced that as well.
And now after a month the car shakes on the highway no matter what the speed it, idle is rough. Shakes for a second when stopped in traffic and I don’t have any codes on the dash.
Should I push the car a bit for it to throw a code.
The car also doesn’t sound good at all.
CAR IS STOCK
TIA
      03-17-2024, 03:39 PM   #2
LuxoM3
(formerly exe36M3)
47
Drives: 2015 BMW 435i
Probably another coil - people tend to replace all 6 of them versus just one or 2.
BMW CCA Member | 2015 BMW 435i RWD, Stage 1 Bootmod3
      03-17-2024, 03:40 PM   #3
Andrew2512
Should I replace all the coils and then wait for it shake, or wait of the code to show up before doing anything ?
      03-17-2024, 04:41 PM   #4
LA430
Drives: 430i
Read codes, find misfiring cylinder, move coil to different cylinder, see if misfire follows.
Parts canon can cost a lot of money.
      03-17-2024, 04:43 PM   #5
Andrew2512
How do I find the misfire, no CEL, should I push the car ?
      03-17-2024, 04:46 PM   #6
LA430
Drives: 430i
Do you have any kind of flashing device or code reader? You’ll need to check live data. I use BimmerLink to check live misfires.
fe7565552.50
      03-17-2024, 04:48 PM   #7
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
I bet if using ISTA+ it will show some hidden (BMW specific) codes that can clue you in to the source. You can buy a $10 ENET cable on Ebay/Amazon and there is a thread on ISTA+ download.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
      03-17-2024, 04:48 PM   #8
Andrew2512
I have bimmerlink how do I check live misfire ?
      03-17-2024, 10:40 PM   #9
LuxoM3
(formerly exe36M3)
47
If you REALLY want to keep testing and you don't have a reader the easiest way is to just unplug a coil and start the car, no change... make note, reconnect and move to the next one.
With a good coil, the unplug will dramatically affect the car - sputters, shutters, chokes, etc. With a bad coil, nothing will happen... and that's the bad one.
Coils aren't known to last forever. My son got 145k out of his 328i/E90 coils before the car started choking, stalling, stumbling. Replaced, problem solved. I'm at 81k on my 435i. Still going but have a set just in case.
I advocate replacing all 6 versus one simply because, the other 5 WILL fail at some point.
fe7565552.50
      03-19-2024, 12:06 PM   #10
Andrew2512
I found the misfire, cylinder 4, replaced the spark plugs and coil and it’s still misfiring like crazy now it’s misfiring even more.
      03-19-2024, 01:38 PM   #11
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
Replaced all of them?
If you made it worse by replacing plugs/coils you probably cracked a plug on install or damaged a coil...
You need a code reader as mentioned above. CEL and "codes on the dash" are totally different than connecting to OBD
      03-19-2024, 02:22 PM   #12
Andrew2512
I connected the car with the reader that’s how I found out it was CYlinder 4.
      03-22-2024, 12:18 PM   #13
LuxoM3
(formerly exe36M3)
47
So where's the misfire now based on the code read?
Silly idea... did you make sure the coil is pushed all the way down onto the plug?
So it makes a snap/pop/click sound? I worked on my 435i once, changed out all the plug and the car misfired like crazy. Turned out, I didn't push one of the coils all the way down.
      03-23-2024, 01:04 PM   #14
E36M3
Drives: 97 M3, '14 335i, '12 X3 35i
Are you using a torque wrench when installing plugs? If so what are you torquing them to? I had a similar issue before I started using a torque wrench. The thin wall plugs crack the porcelain if overtorqued.
