12-14-2020, 12:49 AM | #23 | |
Rep 127
12-14-2020, 08:09 AM | #24 |
Rep 15
I took my car to the technical service. The brake ststem has been checked and nothing is wrong. Also the software has been updated. The problem still persists.
Also we disabled the dsc by pressing the button which is above the mode selection button. The problem still persists. Does it mean that dsc is not the reason? The technical service noticed that headlights turn on when the wipers are on and it turns off when the wipers are off. headlight switch is positioned as Auto. This made him think about rain/light sensor problem. The time of day was such that headlights arent supposed to turn on. We checked the car history and found out that rain/light sensor didnt change when the front windshield was changed. He said rain/light sensor glue should have been changed when the windshield is changed. He also said that auto brake occurs like cruise control brake in terms of intensity. And it cant accelerate as if speed limiter is applied via lim button on the steering wheel. We are gonna replace rain/light sensor and get rid of cruise control buttons and check if the issue is solved |
12-14-2020, 09:05 AM | #25 |
Rep 1,560
Even if the CC is applying the brakes, you can still press the accelerator to over ride the CC and your car will speed up. That doesn't seem to be what you are describing as your issue.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
12-14-2020, 10:05 AM | #26 | |
Rep 15
I know this has very small possiblity but just a hope |
12-14-2020, 12:42 PM | #27 |
BMW CCA 69606
86
Rep 227
Check calibration or replace the brake pressure sensor. If sensor is out of calibration the system may be applying 50 bar pressure rather than the 3 bar required thereby braking the car excessively. You should be able to see the pressure with live data in ISTA while you drive.
BWbimmer276.50 |
12-16-2020, 01:13 AM | #30 |
Rep 15
12-16-2020, 03:41 AM | #31 |
Rep 749
Drives: F31 320d xDrive M Sport
It could be normal brakes, and an abnormal brake-drying function, such as too much pressure applied.
It could be a normally-functioning brake drying function, but with abnormal brakes, so the pressure applied is normal, but a slightly sticking caliper is then applied harder causing deceleration. If it is ONLY linked to wiper blades, then it HAS to be related to the brake-drying function, even if that itself is behaving correctly and the true cause is something else.
12-16-2020, 05:34 AM | #32 |
Rep 15,858
Before throwing parts at the problem, live data would be the wisest first move.
As has been suggested, (by pshovest), try and get the pressure readings during the fault sequence. |
01-12-2022, 07:01 AM | #34 | |
Rep 1
Dry braking problem Bmw F30
I had the same problem, exactly as you described. I disabled it by coding and the problem was completely resolved. Pressure range adjustment can also be made in the brake drying system. but since I don't know the parameter values, I chose to turn it off completely. the code should be like this Enable dry braking ''DSC 3000 c_funktion_trockenbremsen_aktiv_1'' |
01-12-2022, 09:00 AM | #35 |
Rep 844
Brakes are important and yours aren't working well. You should absolutely take this into a bmw dealer or specialist to get it taken care of properly and quickly.
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
04-25-2022, 05:01 AM | #36 | |
Rep 10
11-10-2022, 05:01 AM | #37 |
Rep 1
I have the same issue with my car and its looking like I will have to the dsc unit replaced to fix it. All other options have been looked at inc brake fluids, brakes and calipers.
Just a note of caution - disabling the DSC unit / dry braking (aside from for testing purposes) may void your insurance, warranty etc... |
11-10-2022, 06:34 AM | #38 | |
Rep 15,858
BWbimmer276.50 |
11-23-2022, 04:18 PM | #39 |
Rep 3
Hi !
Were you able to resolve this automatic breaking issue after replacing DSC unit ? I'm having the same issue of ABS/DSC unit applying breaks in rain when rain sensor is on at around 90-100kmph which brings the speed down to 80kmph. And this is happening after short intervals. The worst part is that there are no error logs or codes getting logged into the system. Looking forward to hear back on this thread. thanks, |
11-24-2022, 03:47 AM | #40 | |
Rep 15,858
11-30-2023, 12:26 PM | #41 |
Rep 8
mehmetx HighlandPete njdangelo
I have exactly the same problem. My car is 1.16ed 2014, does anyone know a more economical solution? Like a way to know for sure that the DSC module might be broken? |
12-07-2023, 06:29 PM | #42 |
Rep 1
Had the same issue - fixed
I had the same issue for about 2 months ago. The wet brake wiping feature was overly active whenever the wipers were on at highway speeds. I would typically lose 5-10mph, every 90 sec or so... a little un-nerving.
More recently, the rear brakes were dragging and I could feel hesitation, so I couldn't ignore it anymore. In brief, I took separated the ABS module from the electronics board, ultrasonically cleaned the solenoids, blew air into the orifices, and reassembled. Wala. All good now. |
01-08-2024, 01:54 PM | #43 | |
Rep 20
And I'm going to direct message you because I would really love to speak to you on the phone if possible to figure out how you did this. Thank you! |
01-08-2024, 02:51 PM | #44 |
Rep 833
Drives: BMW F36, E36, E93
The brake drying mechanism applies to all 4 wheels. The isues do not necessarily only occur on the rear.
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
