10-10-2021, 02:36 PM | #1 |
Rep 63
Misfire P0303 ; replaced all spark plugs, swapped coils; no dice
2014/328i/82k Miles/Dinan sport tune/M Perf. exhaust
Car vibrates and stalls when put on drive mode Thought it was a simple fix; replaced all 4 spark plugs with brand new NGK-97506 (SILZKBR8D8S) still P0303. swapped coils between 2 and 3. Still the same code. My next guess is injector, but at the same time I hate to throw parts at a problem. Is there any way to diagnose if the cyl# 3 injector is bad ? Or it could be something else ? Thanks for any pointers
2014 328i | M-Sport |M Blue big brake kit|M Performance Exhaust|Dinan Sport Tune
10-10-2021, 06:42 PM | #3 | |
Rep 1,953
Drives: 2013 328i xDrive
10-11-2021, 08:02 AM | #4 |
Rep 1,597
Before touching the injectors, I would borescope the cylinder and check compression. In the future, when you replace the plugs, that would be a good time to borescope. Injectors are expensive and require more time to swap in and out.
10-11-2021, 12:25 PM | #5 |
Rep 63
Thanks guys! I appreciate the replies and suggestions
I am trying to set up a laptop to install latest ISTA. I have an old laptop setup that I used to run Rheingold with an OBDII to USB cable, but that isn't working for the F30. Looking into setting up the new cable and software. BMWILUVU, I have an HFT inspection camera, but that's too big to fit in the plug hole. what would I be expected to see if I find camera small enough camera to fit in the cylinder ?
10-11-2021, 12:53 PM | #6 | |
Rep 1,597
10-11-2021, 01:57 PM | #7 |
Rep 63
here are some pictures of the spark plugs I pulled. looks alright to me. couldn't find much difference in the appearance, so I didn't mark which one from cyl#3
10-11-2021, 04:35 PM | #9 |
Rep 1,597
Yes exactly slightly more carbon fouling. You should always make sure you know which plug came from which cylinder. The bet is the fouled is cylinder 3. Also,sometimes, a bad coil can ruin a plug and vice versa. I know you replaced all with new but not all at once so I would switch out the coil and plug between 3 and another cylinder one last time and see if the problem migrates before a compression test or take it to a mechanic for diagnosis.
10-12-2021, 01:33 PM | #10 |
Rep 63
Ok, I pulled the brand new plugs I installed last week from #2 and #3. Take a look at the#2 plug, it has more carbon than #3. I am puzzled. Was expecting that on #3, but it's on #2.
With the #2 plug and coil on #3 and vice versa, car still vibrates and stalls. logs error code P0303
10-12-2021, 01:43 PM | #11 |
Rep 63
P0303
10-19-2021, 02:41 PM | #12 |
Rep 63
Ok, I was able to install ISTA and pull the real bmw codes, finally!!
here it is
10-19-2021, 02:53 PM | #13 |
Rep 7,591
Now that you have that capability, you should be able to swap plug and/or coil from #3 to say #1 and see if the problem follows the coil/plug, and if so, replace the problem component.
10-19-2021, 03:41 PM | #14 | |
Rep 63
I am leaning towards the fuel injector next, but before buying a new one, I was wondering if I can try an injector swap between #3 and another without damaging the injector itself? I read there is a teflon seal that gets sealed in when you install a new injector?
10-19-2021, 04:43 PM | #15 | |
Rep 7,591
10-21-2021, 08:11 AM | #16 | |
Rep 1,597
I see you are getting multiple shutdown of injectors so the vibrations. Heres the thing, dealerships when under warranty will get permission for and opt only to replace selective injectors just to get the car back on the road at the least cost to BMW. Otherwise, they often recommend replacing all of the injectors at once. I used to think this was an expensive rip-off but it actually makes more sense for various reasons as explained in ISTA. At the costs they are charging for BMW label injectors it is a rip-off but there is that recommendation hanging overhead. You won't damage the injector if you are careful and since you have ISTA, you can follow the recommended process. I don't know if the 328 does for injector seals but the teflon ones on the B58 are a pain to install as they need to be stretched over the tip and then compressed. The seal rings can be bought at any dealership and cost $5-10 each usually. I always have a few extra around in case I need to go there. You can try swapping the injectors and see if the problem migrates. If you get problems in both, then you need to renew the teflon rings. Either way, when the injectors get reinstalled in-place for good, I would renew the teflon seal. The new injector should have new seals and should be no worries there. This all said, this is expensive and time-consuming to swap diagnose, order, and/or replace all injectors. Before I would do this, I would test the compression on the cylinders to make sure they are holding all in the same PSI range to see if you have any serious issues injectors would not resolve. I would do the compression test first so that you may possibly rule out loss of compression through teflon seals from moving the injectors around. I would say if you are at all unsure about this that I would let a trusted indy or a dealership diagnose and resolve since this can get complicated. For one, if you have a leaky injector, it can give you false positive on compression test for that cylinder. Did you ever have light grey exhaust vapors out the exhaust when your problems happened before injector shutdown? Good luck. Last edited by BMWILUVU; 10-21-2021 at 09:44 AM.. |
BimR245.00 |
10-21-2021, 09:50 AM | #17 |
Rep 234
Let's go back to square one real quick. You have a misfire that's staying in #3 after a plug and coil swap. Your next step would be a compression and leakdown test. I also don't have experience with injectors on this particular engine, but verifying you don't have a ring or valve problem should be your next step before tearing in far enough to get injectors out, and it's something that can be checked in a matter of minutes.
11-14-2021, 02:10 AM | #18 |
Rep 63
Thanks BMWILUVU and heifetz17 for your comments and information, I appreciate it. Have been busy, the car is still sitting in the garage catching dust.
BMWILUVU, No, I don't remember seeing light grey exhaust vapor. Something that I noticed now after the issue is that when it misfires, rpm goes up to 1000 and the exhaust comes out via both the exhaust pipes. Usually only one is open at idle , the 2nd one opens up after 4k rpm or so Where do I get the compression tester that fits the F30 328i? The kit that local auto part shop rents/sells doesn't fit the 328i. I see good and bad reviews about the one harbor freight sells. anyone used that ? Thanks
11-14-2021, 01:10 PM | #19 |
Rep 63
no need for compression test ; the engine is shot for sure. Opened the oil cap while engine is running and the entire exhaust is coming out through it
What are my options at this point ? I bought this car from the dealer as CPO back in 2017. CPO warranty expired in dec 2019. Will BMW do any goodwill if I take it to the dealer? or time to look for a used engine ? Thanks guys!
11-14-2021, 03:00 PM | #20 | |
Rep 500
11-14-2021, 06:33 PM | #21 | |
Rep 7,591
11-14-2021, 07:17 PM | #22 | |
Rep 63
I will post a video Thanks for the comment
