04-22-2022, 04:32 AM | #1 |
Rep 18
340i passenger mirror tilt not working.
I can't seem to pin down my exact problem through search engines. My 2017 340i passenger side mirror, about a month ago, stopped tilting down when the vehicle was put in reverse. Yesterday, after replacing the mirror cap with a carbon fiber one and the turn signal with a smoked sequential one, the passenger mirror would not respond to up, down, left, or right. The drivers mirror received the same upgrades and continues to function as expected. It was starting to become dark out last night, but I was able to confirm that there was the expected "motor noise" coming from the passenger mirror when I was using the switch to make the mirror go up, down, left, or right. So I'm getting a mechanical noise that seems correct, but no actual movement. Did my mirror motor fail? Is there a way to bench test it? Is there anything else I should check prior to bringing it to a BMW dealership? Thanks!
04-22-2022, 09:17 AM | #2 |
Rep 890
The passenger mirror dip in reverse will only happen if the mirror select switch is set to the driver side. It sounds like you might not have the passenger mirror rear attachment installed on the motor correctly after having the mirror cap replaced (so motor moves but mirror face doesn’t).
ReMiii4021.50 AndrewC198910942.50 |
04-22-2022, 09:57 AM | #3 | |
Rep 1,641
04-22-2022, 12:26 PM | #4 |
Rep 18
Thanks visionaut and CajunBMW. I will check into that tomorrow after I get out of work. Finger's crossed I installed the mirror back onto the motor incorrectly.
04-22-2022, 12:53 PM | #5 |
Rep 450
The fact that you said you have motor noises but no mirror movement, hints that something else is wrong now, but originally it was likely the switch was on the passenger side like others said.
04-23-2022, 04:16 PM | #6 |
Rep 18
Fixed it everybody. The switch was selected to the passenger side so that explains the tilt in reverse issue. Somehow I forgot to take my purse off when reinstalling the glass onto the mirror but when I pushed harder and got some movement the mirror works again. Thanks for your help!
visionaut1320.50 |
