09-27-2019, 05:45 PM | #24 |
Rep 203
09-28-2019, 04:00 AM | #25 |
Rep 151
What sizes would be required to upgrade an F30 320i with standard brakes to the blue caliper option , i have 19" 403M wheels , thankyou
09-28-2019, 10:17 AM | #26 | |
Rep 1,453
Anything like these.. |
TopperXP27.00 |
09-28-2019, 12:51 PM | #27 | |
Rep 2,598
I have a set of 340mm calipers available for £329 delivered if interested |
TopperXP27.00 |
09-28-2019, 01:56 PM | #29 |
Rep 2,598
09-28-2019, 02:37 PM | #30 | |
Rep 10,473
https://www.realoem.com/bmw/enUS/sho...diagId=34_1966 |
09-28-2019, 02:50 PM | #31 | |
Rep 2,598
The part number you have posted is for cars WITHOUT option S2NHA (M Sport braking system) F3x cars optioned with WITH S2NHA get part number 34337849878 (that is the LHD part no) which is the same as the ///M master. |
09-28-2019, 02:53 PM | #32 | ||
Rep 10,473
And since when are UK BMW's LHD :LOL: |
09-28-2019, 03:02 PM | #33 | |
Rep 2,598
No arrogance on my end. Simply referring to my experience when looking into the masters for my own project which involved retrofitting F10 M5 calipers to my car. See below - F31 - 330d optioned with M Sport brakes: https://bimmercat.com/bmw/en/search/...0d/ECE/34_1966 Part number for the master is the same as ///M cars. |
09-28-2019, 03:03 PM | #34 | |||
Rep 32,881
09-28-2019, 03:03 PM | #35 | ||||
Rep 10,473
No difference! *sigh* |
09-28-2019, 03:05 PM | #36 | |||||
Rep 32,881
09-28-2019, 03:06 PM | #37 | |
Rep 2,598
Which is the same as the ///M master |
09-28-2019, 03:36 PM | #38 | |
Rep 10,473
The OP pic doesn’t show that. The OP states it came with 17” wheels. Why is he trying to change a F33 Blue Caliper for a F82 Blue Caliper? The fact still remains that the Master Brake Cylinder in the OP’s car will not sufficiently power the F82 Brakes, which is what I originally stated. |
09-29-2019, 02:15 AM | #39 | |
Rep 2,598
It was you that stated: "The master brake cylinder in the F82 is stronger than in the F3x." This is not true, as evidenced by the links on the thread, where many cars optioned with M Sport brakes from factory share the same master. However, it would seem (from looking further since this discussion) that some of the lower powered petrol models do indeed not have the ///M master even when optioned with the ///M brakes. However, this is further proof that the M brakes are compatible with either master!! I also assume you are aware that BMW sell the M Performance brakes for the F3x range? These are the 370/380 4 pots and 345 2 pots, identical to the ///M calipers. This retrofit kit does not include a master cylinder upgrade from BMW.... |
09-29-2019, 02:26 AM | #40 | ||
Rep 10,473
I gave the correct information for his retrofit he needed to know, no matter how you try to justify your response. I did not have MSport Brakes on my 2013 and upon retrofit, the brakes have severe fade as the Master Cylinder does not have the power needed. This was corrected by retrofitting the Master Brake Cylinder and Brake Servo Unit from a F8x vehicle. Real first hand experience. |
09-29-2019, 04:05 AM | #41 | |||
Rep 1,453
09-29-2019, 04:14 AM | #42 | ||||
Rep 32,881
09-29-2019, 07:43 AM | #43 |
Barge driver
8656
Rep 12,425
Don't BMW do an M performance upgrade for the normal 3 series with slotted disks and red calipers, I'd just get that rather than faffing around trying to make things fit that aren't meant to.
730d/Z4C
09-29-2019, 08:49 AM | #44 | |
Rep 2,598
Surprisingly..... it doesn’t include a master cylinder upgrade.... |
Wills28656.00 |
Tags |
420d, brembo, f33 |
