BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Disabling turn signal flash when unlocking?
      10-14-2021, 07:18 PM   #1
fortythirtyfive
Drives: 435i MS
So I'm currently working on custom headlights and the turn signal wire is going to screw with the turn on / turn off DRL animations.
I know I can turn off the turn signal welcome light via e-sys however I need to stop the flashing when unlocking and locking the car. Is this possible?
I have the LCI adaptive led headlights if that helps.
Basically the DRL wire includes a switch back function and the turn signal has priority over the DRL wire, so if the turn signal is active the DRL animation will be cancelled out.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru)
      10-15-2021, 03:02 AM   #2
atzebmw
Drives: Tesla Model 3
No coding needed.
This can be deactivated in the iDrive menu.
      10-15-2021, 03:40 AM   #3
Mike_R_F30
Scotland
Drives: 320d M Sport
This can be coded out with BimmerCode, in the fem module and not even in expert mode.
