BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Spacers on 435i Xdrive
      06-29-2021, 12:08 AM   #1
Maxcadet
Drives: BMW 435i Xdrive
Hey guys, I'm new to the forum and have seen a lot of knowledgable responses so I can use some help. Just installed H&R sport springs along with 245/35/r19 all around and want to fill the wheel wells up more. Any idea what size spacer would be best for flush or maybe a slight poke fit? Especially in the rear. I see 12mm front/15mm rear is most popular
      06-29-2021, 12:49 AM   #2
Emerson335
Emerson335's Avatar
Drives: BMW 335i xDrive
2015 BMW 335xi  [0.00]
I have a 2015 335xi with Eibach springs and factory 18" wheels, and I have 12/18 spacers. I really like this combo as it's pretty equal front to back, with some slight poke all around. I think 10/15 would also be a good combo, with a more flush appearance equally all around.
      06-30-2021, 02:43 AM   #3
Maxcadet
I checked Eibach and they seem to be out of every size wheel spacer. Any other reputable brands?
      07-01-2021, 12:15 AM   #4
J555
Drives: F31 LCI 340iX
What wheels do you have (width/ET)?
H&R spacers are perfectly fine, also like their sets with longer bolts come with security bolts as standard.
      07-03-2021, 05:23 PM   #5
psyki
E36fiend
Drives: 2014 435i xDrive
2014 435i xDrive  [0.00]
2014 X5  [0.00]
I have a 2014 435i with xdrive and adaptive suspension, I lowered with the eibach pro-kit and ran 15mm spacers in the front and 20mm the rear with the stock 18" rims, looked flush or maybe a tiny bit of poke. I have 20" rims now with offset that makes them flush.
Before:
After:
      10-05-2021, 05:54 PM   #6
Maxcadet
Before:
After:
She looks really good man. What size tires are you running?
      10-05-2021, 05:55 PM   #7
Maxcadet
Tires are 245/35 r19 and wheels are 19x8.5 et35 all around
      10-05-2021, 06:41 PM   #8
psyki
E36fiend
2014 X5  [0.00]
Thanks! xDrive so I made sure the front and rears had equal rolling diameter.
245/35/20 8.5" front
275/30/20 10" rear
      10-07-2021, 05:16 AM   #9
Watsey
Drives: F31 330D sDrive M Sport
I recommend you make some allowance for tyre/arch clearance, depending on the ride height of the car.
My F31 is running Ohlins Road & Track with a ride height set at 600mm from bottom of wheel rims to the top of the wheel arches (lowered but not slammed) and there is evidence of slight tyre contact with one particular area of the arch liners.
I don't hear anything when I'm driving the car but clearly the tyres are just grazing the arch liners when there's significant compression of the suspension.
      10-12-2021, 11:17 PM   #10
Maxcadet
275/30/20 10" rear
Do you have any photos on your current setup? I'd love to see them. Right now im thinking since you went 20mm FR and 15mm RR, I should go 15mm FR and 12 RR since my wheels were wider
(prior to you running 245/35 and 275/30)
      10-13-2021, 12:05 AM   #11
psyki
E36fiend
2014 X5  [0.00]
This is the only other picture I have with my current 20" rims:
To be clear I don't have spacers on the 20s, I used those on the stock 18s. I don't recall the offset of the 20s off the top of my head .
