10-16-2021, 04:53 PM | #1 |
M340i
393
Rep 968
Drives: BMW M340i
Rear Shock Question
I noticed on my 435i that the rear shock bump stops have disintegrated. The bump stop is so far gone it no longer holds the plastic cover over the shock shaft. I was checking to see how hard removing the shocks are to replace the bump stops and noticed the shocks do not go back up when compressed. Is this normal on bmw? I've change a few suspensions in my time and the shock always would expand once compressed. Not sure if I should also replace the shocks. I have 61k miles. Car rides fine with no bounce.
10-16-2021, 06:54 PM | #2 |
Rep 1,572
61K miles on your suspension is in the range of starting to wear out. Depends on driving style and roads. The shocks not rebounding is a clear sign of failing/failed shocks. If your rears are going, there's a good bet the front struts are dead, too. I recently replaced my front struts and rear shocks with Bilstein B-4s from FCP Eur at 165K, but they were totally dead. Retains original ride height.
10-16-2021, 08:09 PM | #3 |
M340i
393
Rep 968
Drives: BMW M340i
Never had shock go bad so fast. Not sure if these are gas filled which would rebound faster than non gas. Shocks should not alter ride height unless the wrong ones where installed.
10-17-2021, 10:50 AM | #4 |
Rep 1,572
There are a number of shocks that will change ride height for the model. matching with the correct springs is required. As an example, Bilstein makes several.
10-17-2021, 04:35 PM | #5 |
Rep 1,572
BTW: all the BMW Struts/Shocks and related aftermarket are gas. Which are really a hybrid Hydraulic/gas (usually N2) for more responsive performance. The OEM struts/shocks on my 13 3335i were Sach. I think only vintage/classics cars may still use pure hydraulic for softer/smoother ride.
10-17-2021, 09:23 PM | #6 | |
Rep 5,392
cfm56d7b5886.00 |
