11-20-2018, 10:22 AM | #243 | |
Rep 565
You'll need an ENET cable ($20 on eBay) and eSys software (check the coding forums). After coding the 8.8" screen, you'll get splitscreen functionality automatically for free :-). |
11-20-2018, 10:33 AM | #244 | |
Rep 45
11-20-2018, 10:34 AM | #245 |
Rep 565
The ENET cable is for the coding part. You use to connect the car to a PC/notebook and code it via eSys software. Besides that, you just swap the screen.
11-20-2018, 10:48 AM | #248 | |
Rep 565
I've read this from RealOEM.com, so they should work, but I can't guarantee it - someone with a 1-series should confirm this |
11-20-2018, 10:51 AM | #249 |
Rep 45
Okay :-D can somone with 1 series confirm this please :-)
11-20-2018, 10:53 AM | #250 | |
Rep 565
11-20-2018, 10:53 AM | #251 |
Rep 45
But 65509385202 is a EVO screen? Will it still working to my car?
11-20-2018, 10:59 AM | #252 |
Rep 565
11-20-2018, 11:15 AM | #253 | |
Rep 45
BMW F20 F21 F22 F23 8,8 ZOLL INCH 8,8" NBT EVO NAVIGATION DISPLAY CID 9385202 :-/.. I dont know if I dare to try it out :-D.. |
11-24-2018, 06:37 AM | #255 |
Rep 45
Update..
I Installed the screen, black, nothing it not even booted up, there was only sound from the radio.. until I coded these two lines: HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display and now I have 8.8 navi pro screen, everythings is working perfect! :-D thanks for your help guys! |
MarkoSK121.50 |
11-26-2018, 07:50 AM | #256 |
Rep 565
Great to hear that, enjoy your new screen!
PS: Yes, without coding the screen is just blank or shows NO VIDEO. EDIT: Please post the screen's part number (65509385202?) and your car model for future generations to find |
12-17-2018, 02:59 PM | #258 |
Rep 6
Hi all, I am new with F30. I have a business nav (RL_EntryNav_l15405A) with 6"screen. Just ordered a 8.8 screen (part no. 9292248). Hope this will work. Question is: Will the bigger screen will show next move (turn) for the route on the split screen? Do I need any specific coding for that? I have attached the picture to show what I meant by saying "next move (turn)". Thank you.
12-18-2018, 11:11 AM | #259 | |
Rep 565
12-22-2018, 07:05 AM | #260 |
Rep 1
Screen upgrade from 6.5 to 8.8
Please could anyone help I am new to all this, I am wanting to upgrade to a 8.8 screen if possible please could anyone advise what I need and if this can be done. Details of my version is “Road Map EUROPE 2018-1, RL-EntryNav-Nav-14164A” My car is a 3 Series 320D ED 2014.
Thanks. |
12-22-2018, 05:55 PM | #261 | |
Rep 565
2. Connect a notebook to your car via the ENET cable and double-check (via eSys software) that you have HU_ENTRYNAV head unit (see the coding forums on how to get eSys software) 3. Order one of the compatible screens, e.g., on eBay. 4. Replace the screen (remove the dash by following the first 30 seconds of this video, then unscrew, unplug the small screen and simply replace it with the larger one) 5. Using eSys, code the following entries: HU_ENTRYNAV > EXBOX > DISPLAY_VARIANTE = "breites_display" HU_ENTRYNAV > HMI > DISPLAY_SIZE_RESOLUTION = "8.8_1280x480" (Note: the second one is optional, your car may have it set to a high resolution already - my car had it set to "10.25_1280x480" from factory, eventhough I had the 6.5" screen) PS: Some people successfully used BimmerCode app via WiFi to code this (instead of eSys), however I recommend eSys as it is more stable, since its via cable connection. For further details, see the first post in this thread. Good luck with your DIY! |
Wacko430.00 |
01-08-2019, 06:53 AM | #262 |
Rep 6
Hey all - F20 LCI2 owner here. Looking at an 8.8 inch screen from a 2013 M135i - part number 9292246. Is this likely to function, with coding into a 2018 F20 LCI2 with business nav / Entry Nav?
I seem to remember reading elsewhere there are voltage differences / differences between idrive 5 and 6 which might impact functionality. Also, noting the screen I’m looking at is from a 2013 F20, I wanted to be doubly sure. Any help is appreciated! |
01-08-2019, 08:39 AM | #263 | |
Rep 565
NOTE that 65506822626 is for F30, so if you post your VIN we can try to find the part no. for your car. |
01-08-2019, 05:45 PM | #264 | |
Rep 6
I’ll take a look for screens matching that part number. In any case; my VIN: 5C81622 |
