02-17-2019, 09:06 PM | #309 |
That Libertarian Guy
4039
Rep 6,363
I got extended platinum warranty up to 100,000
02-18-2019, 08:34 AM | #310 | |||
Rep 1,117
Drives: 2015 BMW M235i
02-18-2019, 09:26 AM | #311 |
Rep 1,369
Ahh, makes sense then!
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
02-22-2019, 06:43 PM | #313 | ||||
Rep 77
02-22-2019, 08:06 PM | #314 |
Rep 797
I changed my oil a couple weeks ago and sent it out to Blackstone, just got the email today with the results.
So, A) lucky me and B) what you have above is probably not normal and they don't just send the same stuff to every B58 / they don't all wear like that. Sorry man... I would stay on top of it and if it doesn't change it may not be a bad idea to trade cars and silently pass it to the auction. |
02-23-2019, 12:02 AM | #315 | |||||
Rep 1,117
02-24-2019, 05:33 AM | #316 | ||||||
Rep 77
02-24-2019, 10:35 AM | #317 |
Rep 1,457
I'm not a big fan of the 0w20 and the fact that the oil needs to be replaced by the dealer when the light comes on. I'm full bolt on with meth + E85 blend so in between the dealer oil changes i actually replace my oil around 5,000 miles and when the light comes on i have the dealer replace the oil again.
2024 X3 M40i
2014 BMW M5 |
02-24-2019, 11:02 AM | #318 |
Rep 1,369
Save the Mobil 1 for your lawnmower.
02-24-2019, 04:38 PM | #319 | |
Rep 1,452
2022 CT4-V Blackwing 6-speed
02-24-2019, 10:10 PM | #320 | |
Rep 1,457
Does anyone know if bmw 5w20 exist? I’ve seen 5w30 only.. |
03-10-2019, 07:05 AM | #321 | |
Rep 233
higher the number behind the W you get better oil resistance to higher temperatures....... e.g. m5 e60 had 10W60 ..... the first number represents the viscosity of the oil at certain temperature...lower it is better for your car in winter or cooler climates and you get more MPG out of your car.... higher number... needs more time to heat but offer better protection to your engine..... just my 5 cents..... sorry for poor english....it's not my mother tongue
imperfectluck425.00 |
03-10-2019, 12:49 PM | #322 | |
Rep 1,457
I live in Southern California the coldest temperature we get here is probably 55F lol. I'm simply looking for better protection and i run a E85 blend so my MPG is already out the window.
2024 X3 M40i
2014 BMW M5 |
03-13-2019, 08:31 AM | #323 |
Rep 233
exactly ....i would choose 5w30 or 5w40 due to high temperatures over there
03-13-2019, 08:54 AM | #324 | |
Rep 521
You could probably convince me a 30 weight wouldn't be too thick for the engine, but a 40 weight seems like a big difference to me. Also, with a high-quality synthetic, the difference in weight due to heat is way less than it used to be, so even if your operating temps are 20F higher than mine, I bet a high-quality synthetic would be pretty damn close in viscosity still. If you're ACTUALLY tracking the car, ignore my post. Track usage is much rougher than even serious back road fun. (But I still don't think I'd go above a 30 weight in this engine without closely monitoring oil temperatures and pressure and doing UOA a lot the first time.) |
03-13-2019, 03:10 PM | #325 | |
Rep 1,452
03-14-2019, 06:27 AM | #326 | |
Rep 233
the viscosity or the working temperature you are reaching easily as number 0 before W is telling you that oil is less thick (easier to move) at lower temperatures 0C..... W20 W30 W40 is how much is oil resistant or it's viscosity at 100C.... So if you plan to tune your car or something i would have that little higher.... anyhow follow whatever you have in you manual or given by your local dealer
04-05-2019, 01:59 PM | #327 |
Rep 2
BMW 340IX Msport new engine!!
read a couple of posts about misfire on B58 engines, pulled the error codes, swapped coil packs around and even spark plugs but, did not fix or let the error reset. Error was for cylinder #1, turned out......new engine, zero compression on #1 cylinder. $24K all covered under warranty from BMW dealership. Car was purchased by myself in Germany, and brought back, US Spec, 2016 340ix M Sport, 31K miles.
04-09-2019, 10:33 AM | #328 |
Rep 6
I took my F31 out November 2017, and has since driven about 23 000 km (37 000 miles). Commuting to work (20-30 min) and did a Summer holiday in hot European conditions, plus winter driving where I live. Apart from a burglary I have had no real issues with the car until just recently, but I can list the following:
1. Sometimes a bit tetchy steering, which occurs in about 50 km/h and has reappeared as temperatures start to rise. 2. Occasional bugs with iDrive such as forgetting phones or not playing songs when deactivating mute. Usually disappears after next engine start. 3. Warning for low coolant came last week, just on my way home from work through congestion. I drove carefully without A/C. When anyway standing still I switched off the engine 15 seconds and started again. Warning gone. I checked the level the morning after with cold engine - it was below MIN but I could still see the surface (which due to black container is difficult to assess, but looked ok although shimmery...). The lid/filler had some white residue on the inside, but not much. I put distilled water in, and could get 750 ml until MAX. It sunk a little bit until the next day, when I took the car for a spin. Since then it has kept the level despite normal driving. The small container was almost to MAX, so no issue. From researching here and on German fora I understand there has been many with similar problems. Given that the level seems (so far) to be stable I assume it is the issue with need of topping up once after the factory filling. On the other hand I think it is rather worrying that the warning disappeared despite the level being below MIN. Not confidence-inspiring with regard to what the car actually tells you. My first post here, so apologies if I repeat what everyone already knows... Best, PP |
04-13-2019, 07:53 PM | #329 |
Rep 859
Interesting thread but most of the probs listed aren't with the B58 it's other ancillary stuff like exhaust muffler, HVAC, window trim, etc etc etc. Seems very few issues with the B58
2023 i4 eDrive40
2022 Acura MDX |
B58557.50 |
04-13-2019, 09:59 PM | #330 |
Rep 1,457
It's a pretty solid engine so far as is.
2024 X3 M40i
2014 BMW M5 |
b58 |
