01-26-2018, 03:45 PM | #23 |
Rep 131
01-27-2018, 03:12 PM | #25 |
Rep 131
Quick Update,
Fitted the ACS Sports Suspension today. This is the complete kit with springs and dampers/struts. Was a relatively straight forward process. Having worked on suspension on other BMWs I knew roughly what to expect. To help though I followed this excellent guide: http://f30.bimmerpost.com/forums/sho...d.php?t=994489 I just doubled checked all the torque figures quoted with these BMW guides here: http://f30.bimmerpost.com/forums/sho...d.php?t=970605 All the torque values quoted in the diy guide are almost correct a few of the bolts need an extra 90degrees once you hit the correct torque so double check with the BMW guides if you take this on. I also made sure I had all the correct tools before starting as opposed to improvising. It always makes things easier, so I ordered up a Sealey reach through socket set, which did the jobs needed of it well. I took my time, started with the rear first, lifting the entire rear of the car on to jack stands to take any load out of the roll bar. Then the same with the front, front of the car up on jack stands again to take any load out of the roll bar. It probably took about 7 hours in all. Including faffing to find the front and rear jacking points. I still don't like jacking from the diff which many people suggest but there isn't really an alternative. I only had time for a quick test drive but initial impressions are good. Definitely happy with my purchase. More to follow once I have driven it more and had a chance to capture the 'after' photos, for the all important before and after pictures. |
Lorcan3609.00 |
01-28-2018, 01:30 PM | #26 |
Rep 131
Now time for the all important before and after photos!
A bit different to others who have done suspension work as my after is actually slightly higher than before. As mentioned this is due to the wrong ACS springs being fitted by the previous owner. Looks better imo and certainly drivess better with neutral/postive rake. BEFORE: AFTER |
Lorcan3609.00 |
01-28-2018, 01:39 PM | #27 |
Rep 19,982
Looks ideal height to me. I've got ACS RS fitted and I think it sits just a touch low at the rear, so may look to get it adjusted.
I'd still recommend that you get the alignment done.
01-28-2018, 01:54 PM | #28 |
Rep 131
Absolutely, it will be in at the garage in the next couple weeks for a service, 15mm arb install and full alignment to a custom spec. Nothing too outrageous just slightly less toe in front and rear than standard.
01-28-2018, 02:02 PM | #29 |
Rep 131
Also it should be pretty straightforward to raise the height of rear. I believe the RS kit is manufactured by KW so it should be as simple a threaded spring perch. The KW kit comes with a tool to turn these. All you need to do is take a wheel off and use the tool to turn and raise the perch.
01-28-2018, 02:08 PM | #30 |
Rep 8,493
The arch gaps are spot on IMO. Like Tengo my rear arch gaps are a smidgen lower than that, but it's been OK so far and I can add increase the damper stiffness if needs be.
Nice work Don
01-28-2018, 03:45 PM | #32 |
Rep 131
Cheers guys,
Thought you might like to see the state my rear bump stops were in... Fortunately, I spotted them when doing the brakes so ordered some new ones for the install. |
01-30-2018, 10:27 AM | #33 |
Rep 131
Just posted a review of the ACS sports suspension here:
http://f30.bimmerpost.com/forums/sho...4#post22717844 |
01-30-2018, 10:48 AM | #34 |
Rep 8,493
You posted a link on Bimmerpost to a review you've posted on Bimmerpost :
Good write-up though. Glad you're happy with it What's next ?
01-30-2018, 11:00 AM | #35 | |
Rep 131
Car is booked for the rear ARB and Geometry on the 12th Feb |
03-02-2018, 01:18 AM | #36 |
Rep 131
A little update,
I have had the rear arb and custom geometry on a while now but due to the less than ideal conditions not really been able to comment on how its affected dynamics until now. Before all this snow arrived I managed to grab a couple of hours on empty and dry, albeit cold roads. Traction control completely off and away I went. This is now how I like a car to behave, complete throttle adjustability, albeit with the e-lsd limitations. That said, I was quite impressed with the e-lsd, certainly stops a wheel from just spinning away and enables you to adjust the attitude if the car, but then falls short for any prolonged slides/applications of throttle. How has this effected normal drive ability? Not one bit. Leave the traction on and potter about in 'comfort' and its the same as any 330d. This setup would be perfect for those who want to make this car feel far more responsive to driver input and closer to the dynamics of a much lighter RWD vehicle. For me there is one mod left the Quaife LSD, just waiting for Birds to come back to me with some dates! For reference this is the geometry I asked for. The garage delivered, and all settings where in the middle of the ranges specified: FRONT: Camber : Not adjustable TOE : per wheel 0.04 to 0.08 TOTAL Toe 0.08 to 0.16 REAR: Camber : -1.8 to -2.0 TOE : per wheel 0.09 to 0.12 TOTAL Toe 0.18 to 0.24 |
03-02-2018, 04:46 AM | #37 |
Rep 8,493
Good to hear that you are enjoying the changes as you add them to the car. As a relatively cost-effective means of getting some increase in front camber I can recommend SuperPro camber-adjustable bushes. I managed to achieve 1' 17", and although not as good as installing camber adjustable top mounts, of course, they do make a nice difference.
Let us know what you think of the Quaife diff once you've got the feel for it. I wouldn't be without mine
03-02-2018, 05:02 AM | #38 | |
Rep 131
I was surprised by how little camber it runs as standard. Mine is at -0.3 degrees... All booked in for the 14th at Birds!! |
03-15-2018, 06:15 AM | #39 |
Rep 131
Quick update, Quiafe LSD went in yesterday. So far impressions are good.
Loads more grip pulling out of wet junctions and even more predictable when pushing past limits of grip, basically it delivers what an LSD is meant to, which was to be expected. For now I think the upgrades are done bar swapping out the run flats when they are due. I have accomplished what I set out to achieve with the car and it certainly can put a smile on my face. Just a shame you can't buy them like this as standard. |
03-15-2018, 08:09 AM | #40 | |
Rep 8,493
03-15-2018, 11:28 AM | #41 |
Rep 194
Liking the car mate! Looks just like mine. I've got the ACS sports kit too and I haven't looked back.
Enjoy!
Current: 2022 Tesla Model 3 Performance.
Previous: F31 330d M Sport S Drive with ACS Sports Suspension and DMS remap. Remains the best car I've ever owned! |
03-15-2018, 02:35 PM | #42 |
Rep 131
Oh yes, I like it a lot, after some more miles in it today, it is astonishing how much better the traction is and the fun that can be had.
On another note, whilst at birds, Kevin was keen to take the car out after I mentioned it had the ACS Sports kit on it. He agreed that the ride and performance was much improved but said he could feel the rear oscillating slightly which could be stiffness at the rear or the thicker rear roll bar installed or the fact it is still on run-flats. I personally suspect ACS tune the dampers this way to gain improved rear balance without having to opt for ARB upgrades. I also went out in their demonstrator with the full birds suspension setup which includes thicker roll bars. It was on 20" wheels (non run-flats) which wouldn't have helped but it was definitely not as comfortable as the ACS setup I have, but would probably still be acceptable for those who don't live around horrendous roads. It certainly had less body roll, seemed well balanced and dealt with all the bumps and undulations that were thrown at it. Kevin also told me he has a new setup in works that does not require the ARB changes so should then be on par with the comfort of the ACS setup. Having debated buying either kit myself I am pretty sure I would have been happy with either choice. However, after experiencing both I would still opt for the ACS again. The balance and composure is on par with the birds kit, it might not have as much ultimate grip due to some (not excessive) body roll, but removing that by adding thicker ARBs comes at the expense of some comfort. |
03-16-2018, 06:52 AM | #44 |
Rep 131
