03-18-2020, 12:40 PM | #1101 | |
Rep 15
I get it. So eitheir I pay a fortune to activate the system with OEM FSC Codes or I buy a emulator for the same price that my head unit costed. I think I'll buy the emulator. But tell me, with the emulator I won't have any problems with the dealer and everything will work like factory, right? |
03-18-2020, 12:50 PM | #1102 | |
Rep 40,855
Your car does not have factory navigation option. Even if the FA stored in car is valid for your build and retrofitted hardware, I do not think it can be Programmed by Dealer ISTA. But, you should ask this of Emualtor seller.
03-18-2020, 02:08 PM | #1103 | |
Rep 15
I'll contact an emulator seller in order to know what will happen when I take the car to the dealer to do the recall and the service history registration on idrive. Btw, I checked the menu and I found that now I have the service history of the parts car. Can I change the service history by myself? |
03-18-2020, 02:12 PM | #1104 |
Rep 40,855
No way I know how with ENTRYNAV.
03-19-2020, 11:05 AM | #1106 | |
Rep 2,302
Full is for coding and flashing (ecu updates). If you want to code the active cruise control (Tempomat) you only Need the Lite psdzdata. |
03-25-2020, 03:40 PM | #1108 |
Rep 40,855
PM sent.
03-27-2020, 08:18 PM | #1110 |
Rep 40,855
PM sent.
03-28-2020, 01:17 AM | #1111 |
Rep 12
Hi All, Fired up E-Sys today in an attempt to do some coding read the FA and went to calculate the FP and got the following error
No FP could be generated from FA "". [C002] Not all elements of the FA were found in the FA2FP: HO-Word DSLI [72] I'm assuming I need the latest version of the PSDZ data could someone help...Thanks |
03-28-2020, 08:30 AM | #1112 | |
Rep 40,855
Error is given: Not all elements of the FA were found in the FA2FP: HO-Word DSLI FA is invalid. HO-Word DSLI has dependencies that your FA currently lacks. Fix FA.
03-28-2020, 06:27 PM | #1113 |
Rep 12
Sorry Shawn I'm new to the coding game and the FA was read from the car which made me assume that it would be valid. So I guess I need to determine what these dependencies are...back to Google I guess.
03-28-2020, 09:59 PM | #1114 |
Rep 1
i have the lite version PSdZData_Lite_v4.21.32, but when i read the coding data, it says :CAFD_00000C77_000_007_001 Fehler:
CPS read from ECU "ECUId:EPS_0x30" failed! [C070] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_CPS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: EPS_30_ETHERNET severity: ERROR is it mean i have to use the full version? |
03-28-2020, 10:18 PM | #1115 |
Rep 40,855
So you did not add HO-Word DSLI?
03-28-2020, 10:19 PM | #1116 | |
Rep 40,855
03-29-2020, 05:09 AM | #1117 |
Rep 12
Hello Shawn, thats correct this was read from the car. I have done some searching and I'm yet to find what DSLI is. The only other thing that has been done to the car is that an MHD tune has been loaded which included both a Stage 2 tune and the DCT GTS update.
03-30-2020, 03:42 PM | #1121 |
Rep 40,855
PM sent.
