BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Error lights after spring install
European Auto Source (EAS)
      03-16-2013, 03:30 PM   #1
_r4_
Finland
Drives: F31 320i 13/1
Question Error lights after spring install
Just install H&R springs to my F31. Drove off and all these error lights pop up to my dashboard. Any ideas what can cause this? I also tried to reset the tire pressure monitor but it only gives me FTM system error!
And what the he.. that check engine light doing in there!
Check control:
- Brake system. drive mo...
- Flat tyre monitor (RPA) ...
      03-16-2013, 04:54 PM   #2
MikeVictor
180
I'm guessing you probably disconnected a few things without disconnecting the battery first?
You might need to find a mate with a code clearing tool or take the car to your dealer to make the bad lights go away.
      03-16-2013, 06:36 PM   #3
OCcaraholic
Drives: 2012 328i
I'm guessing you broke one of the ABS sensor wires on one (or more) of the axles while replacing the springs unless you unplugged one and forgot to plug it back in.
2012 328i Sport - Mineral White - Coral Red - Xenon - H/K - PDC - Surround View - BMW Assist w/ Enhanced BT - Premium Package - Fold Down Rear Seat
      03-17-2013, 07:16 AM   #4
_r4_
Finland
Maybe you are right! I didnt disconnect the battery. Does F3x have any warning lights reset option like E9x has?
      03-18-2013, 06:52 AM   #5
MikeVictor
180
Not in itself. You need the right software and a cable or BT dongle to hookup to your OBDII port (in the drivers side foot-well).
      03-18-2013, 10:38 AM   #6
_r4_
Finland
Ok, have to do that. If i'm understand right, nobody else hasn't had any problem after spring install?
      03-18-2013, 06:26 PM   #7
mikew2069
mikew2069's Avatar
356
Drives: F30 335i MSport
No problems here and I didn't unhook my battery. Make sure all of the sensors on the shocks/struts are securely and properly replaced
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      03-19-2013, 02:51 PM   #8
_r4_
Finland
Thats confirm that i had to do something wrong. Do you have xenons? Was your xenon height adjustment right after spring install?
These fault code we find, P15C9 and P15DD.
P15DD - Vehicle speed, wheelspeed sensor right/rear
P15C9 What this is ???
      03-19-2013, 04:19 PM   #9
sydande
Drives: F30 335i
i think you didnt plug all the abs sensors back...check if all the abs sensors are plugged in correctly lol
      03-19-2013, 06:01 PM   #10
mikew2069
mikew2069's Avatar
356
Yes I have Xenons and they seem high now. I need to adjust them but I haven't b/c it doesn't bother me - it only bothers oncoming traffic
I think you should go to every corner, unplug all sensors, blow in them to make sure there's not dust or debri and reconnect. I can't see how it is anything else unless you somehow clipped a line or something but I don't even see how that could've happened.
BM3/H&R/Borla
      03-20-2013, 12:01 AM   #11
_r4_
Finland
All the sensors are plugged in, i have checked tree times now
      03-20-2013, 05:27 AM   #12
PeterM
Drives: bmw 335i
Find out the code and see what sensor is bad, you probably pulled the wires too much and it ripped inside. So they all look find but the wiring is back.
2013 EB2 335i 6MT
