BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 2016 LED Headlights retrofit.
European Auto Source (EAS)
      10-13-2015, 09:48 AM   #67
MSportTune2
Aland Islands
74
Drives: F30 MSport
Originally Posted by knightsabers View Post
Unfortunately no Max mentioned the LHD headlights wouldn't work. I guess, I'll need to start saving for those
Thought so. That's why I asked.
      10-13-2015, 05:47 PM   #68
knightsabers
knightsabers's Avatar
413
Drives: Audi R8 v10 Spyder
The small differences between right/left hand drive
      10-13-2015, 05:48 PM   #69
knightsabers
413
Saw the M3 cluster in his shop. Look awesome!
Can't wait to see it physically quite eager to remove by basic kombi.
      11-03-2015, 12:55 AM   #70
risanta
Drives: 320d F30
Hi,
Have to ask again.
Anyone tried to retrofit these to f30 with halogens.
      11-03-2015, 09:10 AM   #71
Onno299
Drives: BMW 320d sport
Originally Posted by risanta View Post
Hi,
Have to ask again.
I found a supplier in europe: http://www.leebmann24.de/scheinwerfe...117419633.html
But also my question will it fit in a F30 halogen ( Plug and play )
Aftermarket is also available:
Direct plug and play with F30 Halogen models.
http://www.aliexpress.com/item/For-B...519746376.html
      12-07-2015, 01:51 PM   #72
Erics4er
General of the Armies
Drives: 2015 BMW M4
2015 BMW M4  [0.00]
Originally Posted by marius76 View Post
DONE!
without sidemarker
Attachment 1268876
with sidemarker on
Attachment 1268877
LED lights on
Attachment 1268878
indicator light on
Attachment 1268879
Thanks for the post, looking at doing this for my M4, helps that I know a friend that codes. This is definitely helpful. Any issue since the install?
2015 Mineral Grey ///M4 | 2002 VW Golf TDI
2014 Mineral Grey 435i xDrive(sold)
      12-07-2015, 06:20 PM   #73
smithf80
smithf80's Avatar
Drives: '18 F80 M3 6MT
2018 F80 M3  [5.00]
These headlights will not fit your M4.
      12-12-2015, 03:48 PM   #74
szymoncobo
Thanks Marius76
Very nice
Do you have info about mount LED in pre-LCI F30, did i need change FEM module ??
Regards,
Simon
      02-21-2016, 09:54 PM   #75
WilliWP
Drives: F30 320i 2015
Yes, common man can retrofit adaptive LED headlights, however is it not as simple as retrofit of the tailights. If you need custom front wiring harness I can make one for you.
Hi Sir great job for retrofitting the headlights!!, i am trying to retrofit my headlights , can i order the custom wiring from you sir ? thank you
      03-03-2016, 09:07 AM   #76
vierchatura
F30 Pre-LCI Adaptive LED Headlights
How to change FA to add FA $552 and code FLE (43) and FLE (44) ecu's
cant get coded FLE (43) Tried with Esys calculate SVT Target but it not changes anything and not calculate nor swfl nor CAFD for FLE ecu's
Changed year in FA to 112015 added FA $552 but same cant code FLE (43)
FLE (43) is left headlamp ecu.
      03-16-2016, 05:08 AM   #77
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Quick question guys, a friend of mine has a 118i F20 LCI with Halogen headlights. If he wants to install the LED Headlights from BMW is it Plug n Play with some minor coding? Or are there any barriers to completing this?
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      03-22-2016, 09:25 AM   #78
TrickyT
TrickyT's Avatar
Drives: 2015 Alpine White 328i xDrive
Has anyone done a video on doing this install?
I have a 2015 328i xDrive (F30?) US model.
I currently have the Halogens and would like to go up to at least the Xenon and perhaps the adaptive LED headlamps.
If no video, can someone break down exactly what parts and wiring harnesses I need, and if I need to remove the front bumper, etc?
      03-27-2016, 05:06 AM   #79
Icydubloon
Icydubloon's Avatar
Drives: 2013 328i
So my current understanding on how to install a F30 LCI headlight on a pre-LCI F30:
1. You need the LCI headlights which run $1.5K to $2K from various vendors online
2. A conversion harness is needed(?) (see http://f30.bimmerpost.com/forums/sho....php?t=1236659)
3. Coding is required (marius76, http://f30.bimmerpost.com/forums/sho...9&postcount=44)
If someone could provide details for #2 and #3, that would be great
      03-27-2016, 06:12 PM   #80
TrickyT
TrickyT's Avatar
How can I tell if I have pre-LCI?
Does marius76 or anyone make the harnesses still?
Does anyone sell a coding package? I've never done coding in any car and have no knowledge of how to do so.
      04-03-2016, 01:45 PM   #81
marius76
Drives: F30 335i & E90 335d
pre LCI means F30 produced before 07/2015
Yes, I can make such harness
coding can be done remotely. You will just need decent laptop with wifi and ethernet coding cable.
      04-11-2016, 11:34 AM   #82
mkizzo
Drives: F30 335D Xdrive
Hi I'm considering the LED upgrade on the rears only.
Is it simply plug and play?
Any suggestions where to go in UK/Europe for parts?
      04-11-2016, 11:52 AM   #83
scostu
Drives: 2016 F25
This:
http://f80.bimmerpost.com/forums/sho....php?t=1160345
and this:
http://ind-distribution.com/ind/cate...l-lamp-upgrade
Wife's ride....2016 Dodge WD R/T
Retired:2014 F31, 2013 Audi Q5 3.0T P+,
2013 WK2..Hemi, 2011 E90, 2008 E70, 2004 E46
      04-20-2016, 03:22 PM   #84
cailas
Drives: BMW F15 50i 2017
Will "BMW Intelligent Headlight Technology" work after retrofit? are any additional devices required in order for "BMW Intelligent Headlight Technology" to operate?
      04-25-2016, 10:40 PM   #85
Icydubloon
Icydubloon's Avatar
Drives: 2013 328i
It is very straightforward, but not plug and play. I had zero experience with coding (and limited set of hardware tools) and did both the hardware install and software coding in 4 hours.
      04-25-2016, 11:58 PM   #86
Justinandwhat
Drives: 2013 335i xDrive
knightsabers later I will send you PM. I can get a set for you and definitely it will not be 8k.
Can I get a quote too?? Please??? And are they OEM
      05-03-2016, 07:47 AM   #87
maximed3
Drives: bmw320D E92
Hi,
I'm trying already for days and weeks but nobody can code it for me in Belgium. Can you help me with coding ?
      05-03-2016, 09:59 AM   #88
kemiksiz
kemiksiz's Avatar
Turkey
296
İ have a complete headlight set for sale, 4 months old, pristine condition
i am on a f80 LCI conversion process as u May check my threads so no need them any more
PM me please if u r interested in
