BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 2016 LED Headlights retrofit.
      05-11-2016, 10:17 PM   #89
freespirit
freespirit's Avatar
47
Drives: f30 2016 BMW 328i
Originally Posted by Icydubloon View Post
So my current understanding on how to install a F30 LCI headlight on a pre-LCI F30:
1. You need the LCI headlights which run $1.5K to $2K from various vendors online
2. A conversion harness is needed(?) (see http://f30.bimmerpost.com/forums/sho....php?t=1236659)
3. Coding is required (marius76, http://f30.bimmerpost.com/forums/sho...9&postcount=44)
If someone could provide details for #2 and #3, that would be great
Hi
I am new to this forum and new to BMW too. I have a 2015 preLCI 328iX US model with Halogen headlights ... looking for a Adaptive LED OEM retrofit ... what could be the total cost for this and any vendors who provide this
Regards,
Kishore.
      05-19-2016, 09:31 AM   #90
mtx450
mtx450's Avatar
Drives: 2011 E90 M3 ZCP
2011 BMW M3  [0.00]
Can anyone who has done this retrofit confirm if the lights have vertical/horizontal adjustment? I have a 2016 340i (LCI) with these LED headlights and they auto level upon startup. However, I still feel like the light is too low and narrow! Any ideas?
      06-07-2016, 03:53 AM   #91
Icydubloon
Icydubloon's Avatar
Drives: 2013 328i
I went from halogens to LCI non-adaptive LEDs. Still have a few kinks to work out but it seems to be working. It even has the leveling on start up
      06-07-2016, 11:08 AM   #92
scostu
scostu's Avatar
Drives: 2016 F25
Icydubloon
Niceeeeeee......what was the final $$. And did you go with OEM harness or have someone build a harness (adaptor)?
      06-08-2016, 04:07 AM   #93
Icydubloon
Icydubloon's Avatar
Drives: 2013 328i
Originally Posted by scostu View Post
Icydubloon
Headlights $2,000
Custom headlight wiring harness with OEM parts $200
Auto-leveling sensors $200
Misc parts (fuses, wires, drill bits, etc) $50
Misc tools, coding, and installation help $250
Total: $2,700
People finally stare at my car as they walk by
      06-09-2016, 02:51 AM   #94
BMW_1900
Drives: BMW 320d M Sport F30
Fantastic effort!
What types of kinks do you have left?
      06-09-2016, 08:21 PM   #95
Icydubloon
Icydubloon's Avatar
Drives: 2013 328i
I have vertical aim somewhat working but no horizontal aim (I don't have adaptive LED). See image below. Perhaps this is simply the standard with LCI LED?
Originally Posted by BMW_1900 View Post
Fantastic effort!
Working with marius76 to fix some error messages. Also working on getting leveling to work correctly. The beam seems to be too low. Image below shows process after engine on, then turning on the high beams.
      06-10-2016, 07:59 AM   #96
mtx450
mtx450's Avatar
2011 BMW M3  [0.00]
I figured it out. You remove the center section on the white caps and it exposes the horizontal adjustment. It doesn't really change that much. Not as dramatic as the vertical adjustment.
Check here for more info.
http://f30.bimmerpost.com/forums/sho....php?t=1262875
      06-15-2016, 10:56 PM   #97
freespirit
freespirit's Avatar
47
Headlights $2,000
Total: $2,700
I am seriously looking for this retrofit ... Can you please let me know the part number or if you are working with some one to get this retrofit please let me know I would like to join too
Thanks & Regards,
Kishore Kumar.
      06-17-2016, 11:40 AM   #98
JamRWS6
Drives: 2016 340i
If you don't have the adaptive headlights you won't get the horizontal functions. The retrofitted lights being posted here are the adaptive versions. I can't speak for the regular LEDs but the US spec coding on these lights isn't that great. The euro coding is much better.
- 2016 340i
- 2015 335i xDrive
- 2014 X3 35i xDrive [Sold]
- 2012 535i [Sold]
      06-19-2016, 07:57 AM   #99
maximed3
Drives: bmw320D E92
Im looking for someone to code my lights. I did already THE installation but they didnt work. When i start the car the light doesn't work and I have to take out the fuse and put it again and then it's working. THE adaptieve system and THE high Bram assistent didn't work Also. Can someone help me ?
      06-21-2016, 04:04 AM   #100
Icydubloon
Icydubloon's Avatar
Drives: 2013 328i
Turn off the engine, get out of the car, and lock the doors. Wait 30 seconds. Then unlock the car. Do the headlights turn on for 1-2 seconds (then go off)? Or do they not come on at all?
      06-21-2016, 10:38 AM   #101
JamRWS6
Drives: 2016 340i
Which lights did you install? Adaptive LED? Have you loaded E-sys? Does it recognize each of the front FLE ECUs? I'm assuming adding to the VO and VO coding FEM and the FLEs would be necessary. Do you have KAFAS or FLA camera on your car?
Probably can help more once we know these things. FWIW I have never retrofitted this but these will be some pretty basic coding changes that would be required.
- 2016 340i
- 2015 335i xDrive
- 2012 535i [Sold]
      06-21-2016, 04:18 PM   #102
maximed3
Drives: bmw320D E92
I tried seceral times with a friend he can work with e-sys. But it's seems like the car don't recognize the light and powered them.
I fitted the adaptive led on the car. But the car had already adaptive xenons with the high beam assisted.
So I don't no what I have to code ...
      06-21-2016, 09:13 PM   #103
JamRWS6
Drives: 2016 340i
What ECUs are recognized in E-Sys? Need to determine if it will even recognize the lights to confirm they are connected properly. There is also a teach in process via Rheingold that BMW says should be run when headlights are replaced. All of these are good places to start. Unfortunately without this kind of information we don't really have a chance at helping you out. Just "they don't work" and "a friend tried ESys" won't get us anywhere. Not trying to be terse but there just isn't enough information and troubleshooting to make progress.
- 2016 340i
- 2015 335i xDrive
- 2012 535i [Sold]
      06-26-2016, 04:46 AM   #104
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
35
Drives: e92
Exclamation
Originally Posted by marius76 View Post
How can I tell if I have pre-LCI?
pre LCI means F30 produced before 07/2015
Does marius76 or anyone make the harnesses still?
Yes, I can make such harness
Does anyone sell a coding package? I've never done coding in any car and have no knowledge of how to do so.
coding can be done remotely. You will just need decent laptop with wifi and ethernet coding cable.
hi
can you please help me code my lights? i am from romania. a phone number or email will be highly appreciated
multumesc
      06-28-2016, 06:16 PM   #105
Robby29
Robby29's Avatar
Drives: AP M4 / Z3 2.8
thanks to this thread, I found the right people to help me retrofit LED for my f36
http://f30.bimmerpost.com/forums/sho....php?t=1276098
      07-02-2016, 04:11 PM   #106
dumitru.o
coding BMW.....
dumitru.o's Avatar
Romania
35
Drives: e92
managed to code my F80 LED Adaptive headlights into F30 2011. will soon post some pics
      07-06-2016, 01:18 PM   #107
Sharp_Cai
Sharp_Cai's Avatar
100
Drives: 2013 BMW 335i
Need find someone who is able to do the install and coding in NorCal area.
2016 BMW X5 MW M Sport MPPK MPE
2018 Tesla Model X 100D
      07-06-2016, 02:57 PM   #108
jmichaelh7
jmichaelh7's Avatar
Drives: Black bmw
I've been searching forever to find a way to install xenon or LCI headlights. Robby29 can you PM me about info on getting setup with your guy? Or Dumitro.o do you mind PM with info how you went about setting up your ride?
TIA,
      07-09-2016, 01:55 AM   #109
CazuaLLUK
Drives: 2014 335i Black F30 M Sport
I have read this whole thread and checked out the costing. Am I missing something? BMW quoted me 1700 to remover my Halogen and installed OEM Xenons?
Surely with all this cost, it would be worth going OEM?
      07-10-2016, 04:46 AM   #110
scostu
scostu's Avatar
Drives: 2016 F25
Check this......not sure about RHD though...
http://f30.bimmerpost.com/forums/sho....php?t=1274932
http://f30.bimmerpost.com/forums/sho....php?t=1257101
