BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Front Park Distance Control (PDC) Retrofit DYI
European Auto Source (EAS)
      03-12-2016, 10:18 AM   #89
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
Originally Posted by hugoalvim View Post
Justo some questions:
I don't find the first item:
Install.kit, Park Distance Control,front 66202338070 1x
Where do you buy it?
This item include:
61 13 1 367 599 Cable tie
61122334361 Retrofit cable set, PDC front 1 $89.07
01 29 2 338 017 Installation instructions1 $0.00
66 20 6 923 000 i Decoupling ring PDC torque converter4 $1.99
The 61122334361 Retrofit cable set, PDC front 1 $89.07 Don't included the Cable Set Front bumper 61129260019????
Thank you.
Hugoalvim,
My error; I purchased the front PDC retrofit kit from PartsSale.EU: http://partsale.eu/index.php?option=...fice.dashboard
This company was used by others who had done this retorfit. Be very patient as they take a long time to get it to you -- if I recall, it took me about 2 months to get the parts from them
Hope that helps!
Al
Retired: 2014 328i
BMW CCA
      03-12-2016, 10:47 AM   #90
Mewp
Drives: F32
This item include:
Thank you.
You can buy the parts to build your own retrofit cable. It's not very difficult, and much cheaper. You need:
1 x 61138383300 - socket housing
12 x 61131383776 - socket terminal
6 x 61138353705 - rubber grommet
6 x 22AWG wire, about 6 meters long each. You can probably find this at a local hardware store or get it off Ebay very cheap.
I can post instructions on how to put it together if you need them.
      03-13-2016, 10:46 AM   #91
sang_90
Drives: f30
thanks for share
      03-14-2016, 06:24 PM   #92
hugoalvim
Drives: 320i Sport
Yes I want. Thank you.
Originally Posted by RSnic View Post
Hugoalvim,
Hope that helps!
Helps a lot. Regards.
      07-04-2016, 06:45 PM   #93
ivannw
Drives: BMW 316i
Hi Mewp!
I'm from Brazil also and I want to do those retrofits in a f20. For rear and front.
I don't know yet if my REM has the pins to it.
I found the kits in the local dealer but it's a little bit expensive. Kind of 500 usd both.
I will need also the sensors and maybe the REM.
1) can you provide us the instructions?
2) let's supose I will need the rem, there is some kind of limitation to buy it? Can I buy it from a f30, for example?
3) i have hu_entrynav. Is it capable to work with pdc?
Thanks in advance!
      12-19-2016, 05:09 AM   #94
dengus
Drives: 320D f30 2013
Sorry if this is an stupid question but where is the ICM located? Is that the airbag module?
Thanks.
      12-19-2016, 08:04 AM   #95
atzebmw
Drives: BMW 335XD F30 LCI
Thanks.
The ICM can be found under the center console.
I would say in the middle behind the gearshift.
And yes, it's also responsible for the airbag.
      12-28-2016, 05:50 AM   #96
dengus
      02-15-2017, 09:42 AM   #97
Stafelalp
Drives: E91
An update for UK users:
I have just successfully achieved this retrofit but UK RHD owners need to be aware that you have to order the following part numbers. My vehicle is a 2013 F31, so check with your parts supplier if there are differences for other model years.
1 retro kit - B66.20.2.338.070
4 sensors B66.20.9.261.582
1 switch B61.31.9.252.921
1 holder kit B51.11.7.324.343
1 cable set B61.12.9.313.607
Note that -
1) switch for LHD cars, B61.31.9.252.912 (last 2 numbers transposed) will not fit a RHD car. BMW are being their usual un-cooperative selves with me, refusing to take back my LHD version I ordered in error, so if anyone on this forum wants a bargain brand new switch for a LHD car please contact me on d.r.chadwick@btinternet.com.
2) the retro kit includes only part of the items you require. I do not understand why this is the case.
3) the sensors need painting with the colour of your car. You can order pre-painted ones at c250 ea cf 100 ea for unpainted. Total cost parts + labour to fit c 900. In hindsight, far too much money, but it does work very well, integrating nicely with the existing rear system. Much better than non-BMW retrofit, but not sure if worth the extra.
4) I cannot comment on the fitting/software changes as my engineer did the job, but he did not report any problems (possibly because he is extremely capable)
      05-01-2017, 09:17 AM   #98
jkwhar
Drives: F30 328i Xdrive | F15 x35i
For those looking for the PDC sensors...18.99 each OEM BMW (black) and free shipping! (Not affiliated with the seller, just helping other members out.)
http://www.ebay.com/itm/301733207844...%3AMEBIDX%3AIT
F30 328i xDrive | 475 BSM | 2A5 18" | Cold Weather | Nav Pro | Tech Pkg | Injen Intake | CW DP | VRSF IC | MR Dual Exhaust | BM3 | BC coilovers | Swift springs | Integral Audio | Retrofit: 522 & 524 EDM | 5AC | VLD | 2TB SAT | 508 | 3AG | 5DL | 6WB | 8TH
      06-04-2017, 11:01 AM   #99
rflagg
Drives: F31
I'm trying to wire up the ICM and already removed the center trim around iDrive controller as well as the handbrake trim, but there's no way to access the plug from there. Is going through the rear vents the way to go?
      06-04-2017, 02:19 PM   #100
jkwhar
Did you unlock the plug? Its the typical bmw swing-over type lock.
I had to use a pick tool to get it out and back in and all I took out was the center trim and ebrake boot, although, I do have small hands.
rflagg6.00
      06-04-2017, 02:30 PM   #101
rflagg
Drives: F31
Thanks for reply. No, I couldn't even reach the plug. It was getting dark already so I might have missed something but it looked like the air duct going to the rear covered the ICM module almost completely, I could only see a glimpse of it. Was yours like that too?
      06-04-2017, 02:32 PM   #102
jkwhar
Yup, there is the rear vent duct. Also, keep in mind that on the ICM where the plug would plug into, the top cover of the ICM extends out. Heres a photo but its upside down.
EDIT:
What I did was use the ebrake boot to access the ICM wiring harness. The locking click is on that side, so use your finger to feel for it and use a picktool to help you swing the locking mechanism. Putting it back was harder for me as I couldn't see where I was putting the harness back into the ICM since the limited space.
rflagg6.00
      06-04-2017, 02:36 PM   #103
rflagg
Drives: F31
Well, that then looks (and sounds) like a total pain to get to
Thanks for the tips, I'll take a better look tomorrow or so. I have small hands too so I'm not going to give up just yet, although it looked like the center console assy isn't too bad to remove either.
      06-04-2017, 02:37 PM   #104
jkwhar
Check my update on my last post and I'll see if I could take some photos for ya.
      06-04-2017, 02:40 PM   #105
rflagg
Drives: F31
Just checked, you really went through the ebrake boot? You have to have really small fingers, it looked like there's only so little space there.
Some photos would be much appreciated but no stress about it.
      06-04-2017, 03:13 PM   #106
jkwhar
So I lied, lol. The locking tab is on the other side, about half way in. the 3rd photo is an example of the harness/connector but not the actual one.
Here are some photos I just took.
Jammed my phone camera from the ebrake boot.
The ebrake boot opening
Not the actual plug but an idea where the lock is located.
      06-05-2017, 11:54 AM   #107
rflagg
Drives: F31
Thanks a lot! Seems same as mine indeed. It's pretty crazy that you could actually unplug and plug the cable from that tiny opening but I'll try tomorrow or so, didn't have time today due working late, meh.
      06-05-2017, 01:33 PM   #108
jkwhar
My hand didn't technically go in all the way. Just the fingers, enough to feel and push/pull. The pick tool helped ALOT.
Feel for the push tab (this prevents from the swing locking arm from undoing itself) on the plug with one finger and press it towards the front of the car and with the other finger try to pull the swinging lock. If you cant swing that all the way, just swing it enough that its slightly pass the push tab and holds it down and use a pick tool to grab and swing/pull towards you.
      06-06-2017, 02:24 PM   #109
Davef30hull
Drives: 2013 F30 msport
This item include:
Thank you.
hi could you send me the instructions please?
      06-06-2017, 11:43 PM   #110
jkwhar
I ordered the items on that list. The rubber grommet didn't fit the socket housing, maybe it was me but it was too big (61138353705). I didn't try to figure out the correct one, just took some hot glue and filled it in so water/moisture didnt get into the socket housing.
I order 25 feet of 22 gauge TXL wire from ebay, you will need 6 different colors.
Since I did the rear PDC, I know that the pin #12527522387 works so I ordered those for the REM side and for the socket housing, the pin listed in the instructions (61131383776).
All you have to do is crimp the pins to the new wires for the PDC side while noting which color on the front apron its lines up with. The PDC front apron harness has 6 colors, match those to the wires you're making. After running the wires cut the length when you get to the REM while keeping some slack. Pin those wires and then go back to your notes. Its really simple.
