BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding cable and ESYS, psdzdata
      08-15-2018, 01:22 PM   #2355
cyberninja
Drives: F31
Originally Posted by atzebmw View Post
oops.. thank you dude.
      08-22-2018, 04:45 AM   #2356
jalami
Drives: f30
Hi .
to encode( VO and condig FDL) id5 and id6, it has to be through the connection OABR.??
or it can be done as NBT1?
Thanks advance
      08-22-2018, 06:19 AM   #2357
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by jalami View Post
Hi .
Thanks advance
No. E-Sys and ENET Cable is all you need for Coding ID5 => ID6.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      08-22-2018, 10:45 AM   #2358
deneyer
Belgium
19
A question im also running esys in vmware, i tried to code an bmw f30 from 2018 but i didn't get acces cause i didn't have the right cafd file. Is it possible to code 2018 cars when windows in vm is set on 2016
      08-22-2018, 10:53 AM   #2359
shawnsheridan
What is meaning of "vm is set on 2016"?
Latest E-Sys Launcher PREMIUM 2.8.2 will not run in VM. Older versions are expired. So, only VM option as far as I know is E-Sys Launcher PRO.
      08-22-2018, 11:15 AM   #2360
deneyer
Belgium
19
Yes i still run the old free esys launcher with vm ware windows 10 set on year 2016 so.
But i think if i update the pszd data to latest version so i also have files for 2017 and 2018 it wil interupt esys cause it only works till 2016
You understand?
      08-22-2018, 11:35 AM   #2361
shawnsheridan
You understand?
You can update your PSdZData in VM, and still use your time-hacked Launcher, but at some point, this will become useless as the CAFD Mapping Database in Old Launcher is Old, and not being updated.
Rather than using hacked Launcher PREMIUM you are far better off getting PRO version from Developer.
      08-22-2018, 11:40 AM   #2362
deneyer
Belgium
19
I understand but im not going to pay for something that i only use for personal use. If i was doing it proffessional and had a lot of work i could think about paying for the pro version but to code my care if i do a retrofit. Don't see the point of it
      08-22-2018, 11:56 AM   #2363
shawnsheridan
I don't get your point really. If something benefits you, whether you monetize it or not, it has value. Most everything one buys in life is not used for commercial benefit. But, suit yourself. Dodge Launcher PRO's $50 Charitable Donation requirement, but get stuck with old outdated Launcher PREMIUM. Good luck with it.
      08-22-2018, 12:04 PM   #2364
deneyer
Belgium
19
My car is from 2014 so i have no problem coding my car with my old outdate launcher as you call it
My friend has the 2018 f30 and was just to help him out but he will have to find another sollution then. Find a coder who has updated software and pay for it
      08-22-2018, 12:13 PM   #2365
shawnsheridan
Or just use latest E-Sys Launcher PREMIUM 2.8.2 on a Windows PC like most everyone else does, and then VM restriction is not an issue...
Incidentally, build date is irrelevant. Firmware version is what matters. A 2014 car with latest firmware depending on ECU List will have CAFD Mapping issues, same as a new car would. But if old outdated date-hacked VM version still works with your current firmware, then by all means keep using it.
      08-22-2018, 02:02 PM   #2366
deneyer
Belgium
19
Who knows maybe ill be forced to get the new software, cause im about to do a 6wb retrofit in my 2014 f34 so it can be that i will get issues when i will code the 6wb I will see
      08-22-2018, 04:35 PM   #2367
Davey78
Drives: 2014 328i
E-sys
Hey Shawn, can I get a link to the updated E-sys and psdzdata?
      08-22-2018, 04:44 PM   #2368
shawnsheridan
PM sent.
      08-23-2018, 01:40 AM   #2369
jalami
Drives: f30
Thanks shawns
if it is a retrofit evo id6. (ATM emulator) VO and FDL. I need to code it from OABR. or not??
You can send me the latest psdzdata?..please.
Thanks for advance.
      08-23-2018, 03:06 AM   #2370
shawnsheridan
Thanks shawns
Thanks for advance.
I think you can still code via OBD Port. PM sent..
      08-28-2018, 01:11 PM   #2371
carmania
Drives: F10 530d
esys not working on f56
Hey shawn,
unable to use the esys software for mini cooper F56 2015 model.
Though i used the same software for F10 last month, but its not working with F56.
Connection is successful. There after upon clicking on coding- READ vehicle order, FA list folder is shown, but when i click on read SVT, error message pops up. (service returned global negative response). Please refer attachment for error snapshot.
I also changed the model from f10 to f56 in esys launcher premium.
Any pointers will help.
As software was used for F10 previously, do i need to uninstall and reinstall the same with f56 configuration.
      08-28-2018, 01:21 PM   #2372
atzebmw
Drives: BMW 335XD F30 LCI
Originally Posted by carmania View Post
Hey shawn,
Choose F56 at the start of the Launcher.
At the connection window connect as F056.
No need to reinstall something.
      08-28-2018, 01:34 PM   #2373
shawnsheridan
Hey shawn,
You need to use Read ECU instead of Read SVT.
      08-30-2018, 10:44 AM   #2374
merit
Thx
      08-30-2018, 11:19 AM   #2375
shawnsheridan
Thx
PM sent.
      09-01-2018, 06:47 AM   #2376
cesaroctavio_80
cesaroctavio_80's Avatar
Mexico
Drives: 3 Series F30
Hi shawnsheridan.
Again in the F30 road Id like to add the cruise control to my 318 i bmw. So im going to buy this cable
https://www.amazon.com/gp/product/B0...3K69FZB4&psc=1
Also the steering wheel Ctrl
https://www.ecstuning.com/b-genuine-...s/61319261859/
Last missing part is coding SW.
Can you please help me?
Have a nice day
