BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Enable DAB NBT5
      01-17-2020, 05:07 AM   #1
thaking
Drives: E90 FL / F31 FL
Enable DAB NBT5
Does anyone have DIY to enable DBT on NBT units with professional radio, navi..?
      01-17-2020, 08:12 AM   #2
atzebmw
Drives: BMW 335XD F30 LCI
This works only if your NBT has the DAB-Tuner.
Add the "654" to the VO and then code the NBT with it.
      01-17-2020, 12:49 PM   #3
thaking
Well how to know if I have it (via VIN finder I can not find it...)?
      01-17-2020, 01:17 PM   #4
atzebmw
If you didn't retrofit the headunit DAB should already be activated.
If it isn't activated or you can't find it via VIN the car doesn't have it.
To be sure you should remove the headunit and check the part number or the connections at the back of the HU.
      01-17-2020, 01:32 PM   #5
thaking
Thanks, Car is from Germany and have a lot of add. equipment (nbt5, carplay, professional etc...), but don't have so called "S654A" option - DAB.
