BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > bootmod3 for BMW F series Vehicles - General Discussion
proTUNING Freaks
      02-22-2020, 10:21 AM   #2817
Phantom10R
Drives: 2015 335i, 2015 X3 x35i
Originally Posted by romemedrano View Post
Thanks for giving us an update! I probably won't have time to test this out gotta prep for track weekend next week! If Phantom10R and JaredG_F30 says it's good I'll flash it on track and do a few sessions on it!
I wont be messing with it. Lets just wait for JaredG_F30 lol
2015 335i xDrive - 2015 X3 x35i
IG: @N55David
Youtube: @ n55david
      02-22-2020, 02:07 PM   #2818
TR-8R
TR-8R's Avatar
Drives: Alpine White 13' 335xi M-Sport
Also having connection Issues.
I'm trying to reflash but I'm being told my OBD agent isn't up to date. I have updated in the app multiple times but every time it "successfully" updates to the newest version my connection drops out and will not re-connect. Once I turn everything off and connect I have to do this same process over.
I've reviewed the troubleshooting page, disconnected the battery, renamed the hotspot name, ect..
This is what happens every time I try and flash
13' 335xi PWG M-Sport 8spd - BM3, CTS Turbo FBO, H&R Sport Springs + Spacers, BMW MPE
      02-22-2020, 02:13 PM   #2819
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
If you're using your phone, try hard rebooting and log back in
My Build Thread can be found HERE
      02-22-2020, 02:39 PM   #2820
TR-8R
TR-8R's Avatar
Thanks for the reply, have been trying but still not fixing the issue
      02-22-2020, 04:10 PM   #2821
Phantom10R
Delete the app and reinstall after restarting phone
      02-23-2020, 02:23 PM   #2822
TR-8R
TR-8R's Avatar
I tried this as well and no fix. I am manually reinstalling the update on my SD, hopefully this does the trick
      02-23-2020, 02:27 PM   #2823
hybris
hybris's Avatar
Norway
170
Drives: BMW 330e F30 M-sport
So, I have two peculiar logs:
http://www.bootmod3.net/log?id=5e5107a5d10b4377fa625dce (around timestamp 300)
http://www.bootmod3.net/log?id=5e5107a5c090c6505e94e79b (around timestamp 90)
I have overboost at both these points, and both events are me loosing traction and the traction control kicking in. So the throttle is at 100%, but my RPM is going down because the traction control is trying to regain control. Apparently this makes the turbo spin freely and overboost (?)
What do we think about that? Assuming overboosts like this is a bad thing, loosing traction isn't good for the turbo.. ?
Thorbjorn
16 BMW F30 330e M-sport
Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs
      02-23-2020, 04:54 PM   #2824
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
Yes, reflash the firmware into the agent and then update it, and that did the trick for me.
2013 335i xDrive
Bootmod3, Pure Stage 2, Pure Inlet, GFB DV+, AFE Pro Dry S Drop-in Filter, ER CP/TIC CP, ER Catless DP, ATM FMIC, Borla ATAK, Dinan Springs, Dinan Shockware, XHP ZF8AT Stage 3, xDelete
      02-23-2020, 08:03 PM   #2825
TR-8R
TR-8R's Avatar
I can confirm this worked for me. Flashed Version 8.1- Stg 2 91Octane and the 8spd Flash, very smooth power delivery.
Here are 3 Pulls. I notice the knock early on when it drops to 2nd gear, but I am not sure why my boost is so under target. Timing looks decent but best in 4th gear. Would appreciate a trained eye to see if they notice anything.
http://www.bootmod3.net/log?id=5e531942d10b43252d323edd
http://www.bootmod3.net/log?id=5e531994d10b43252d323ee2
http://www.bootmod3.net/log?id=5e531bfbd10b43252d323ef3
      02-23-2020, 08:11 PM   #2826
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
Do a proper log.
If you aren't familar, you need to do the log in 3rd if 6MT or 4th if 8AT, start at about 2000 or 2500 RPM, floor it (dont roll into it) and log until about 6k or 6500 rpm and stop the log. Get maybe 2 logs like that. Remember to have DSC fully off and place shifter into manual mode.
      02-23-2020, 08:17 PM   #2827
harkes
harkes's Avatar
China
744
Drives: M135i, NSX and AE86
Your overboost is from the gear shift. 100% normal. Your can see throttle is closing to control it.
MAP[psi] is what is actually going into the engine (post-throttle)
Boost[pre-throttle] is exactly that
M135i PWG, MHD, Pure Stage2, Torqbyte CM5-LT, xHP
(A Dane in China)
hybris170.00
      02-23-2020, 09:04 PM   #2828
jcordier
jcordier's Avatar
Drives: 2013 black F30 N55
Do you have the gts start up roar turned on? I have it turned on and it doesn't as good as 8.0.
J. D. Cordier
      02-23-2020, 09:35 PM   #2829
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
I normally log by going 2nd gear 2500rpm to 6800rpm in every gear up to end of 5th (I have PS2)
http://www.bootmod3.net/log?id=5e531...yRnNhBwDMPKGMs
Boost is under target on purpose to raise timing, of course fuel might play a tiny part in it (In canada we got winter blend gas in the east so fuel becomes very shitty during winter)
2013 335i xDrive
      02-23-2020, 09:38 PM   #2830
TR-8R
TR-8R's Avatar
No, not yet
      02-24-2020, 05:29 AM   #2831
hybris
hybris's Avatar
Norway
170
Thank you, so nothing to worry about despite the pre-throttle boost being high then?
Thorbjorn
      02-25-2020, 02:30 AM   #2832
ChristosD
ChristosD's Avatar
South Africa
90
Drives: m135i
my obd agent is at the latest firmware but when i try flash v7.1 ewg map this keeps happening? i have deleted and downloaded the map 3 time, i have also tired to download now flash later nothing works
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// GFB DV+ //
//CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 S2 E30 AGG V7.1 //
      02-25-2020, 06:56 AM   #2833
Phantom10R
Delete the app and reinstall..
      02-27-2020, 04:50 AM   #2834
ChristosD
ChristosD's Avatar
South Africa
90
Drives: m135i
thanks bud tried that also disconnected battery nothing worked. SD card was corrupted had to flash it manually all is good now. PTF's guide is great for this
      02-28-2020, 07:06 PM   #2835
stlb5
stlb5's Avatar
108
Drives: '14 M235i MT, '15 X5 Msport
Got a pull today on 7.1. This is on 93 octane. I see some timing being pulled. Is it much? Could it be due to winter fuel blend?
http://www.bootmod3.net/log?id=5e596488d10b43776c7d9824
2014 M235i MT, BSM, MPE, Dinan Springs (His)
2015 X5 Msport, CB (Hers)
      03-13-2020, 02:06 PM   #2836
proTUNING Freaks
proTUNING Freaks's Avatar
3410
Drives: powered by bootmod3
*** UPDATE:
https://f30.bimmerpost.com/forums/sh....php?t=1703074
      03-13-2020, 06:31 PM   #2837
designatedposter
Drives: m235i
Yes timing drops seem a bit much. I would recommend using the 91 octane tune
      03-13-2020, 06:33 PM   #2838
stlb5
stlb5's Avatar
108
Drop to 91 or add boostane? I have plenty. If so, what target octane?
