BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > xDrive All-Wheel Drive Discussions > xDrive or not? anyone test side by side?
      01-19-2016, 11:32 AM   #67
Outlaw 06
Outlaw 06's Avatar
Drives: M240i (daily driver)
Originally Posted by I'm wrong View Post
You shouldn't use 225/50 17 as that is over 3% taller than the OEM specs.
OEM is 225/40 18 or 225/45 17. They differ 0.4% only (so they match).
I bet your car with 225/50 is, albeit "more cushioned" or comfortable, slower, worse in curves and worse when braking. These are the trade offs for going with taller tires if you're looking for more "rubber" for comfort.
Cheers
You're wrong. My car's stock M Double Spoke 400M staggered summer wheel/tires are:
Fronts: 18x8.0, 225/45 R18 (tire OD of 25.9" x 8.9" wide).
Rears: 18x8.5, 255/40 R18 (tire OD of 26.0" x 10.2" wide).
My square 17x8, 225/50 R17 winter set-up has a tire OD of 26.0" x 9.2" wide.
The ODs are almost exact between my 18" summer and 17" winter wheels/tires.
      01-19-2016, 11:33 AM   #68
Outlaw 06
Outlaw 06's Avatar
Originally Posted by cptcrunch View Post
So if the front is 225/45/18 and rear is 255/40/18s, whats the correct winter tire? Based on the tire calculator (tacoma site: https://www.tacomaworld.com/tirecalc...0r18-225-50r17) 225/50/17s are the correct size.
You are correct.
      01-19-2016, 11:37 AM   #69
NOITALL
Drives: 4 wheels
You are correct in saying a 225/50 17 will match a 225/45 18 or 255/40 18.
You are wrong in saying OEM is 225/45 / 255/40 18. These tires are over 3% the OEM size and I maitain the trade offs that come from such decision.
Cheers.
      01-19-2016, 03:12 PM   #70
ynguldyn
Drives: battery powered tv on wheels
No.
Please check the ordering guide or the specifications on the web site.
      01-19-2016, 04:20 PM   #71
NOITALL
Drives: 4 wheels
Originally Posted by ynguldyn View Post
No.
They don't make E90s anymore... I would though.
In any case, if that is true, then BMW sold the car with 2 different wheel/tire diameters (one for the 17" set and another, taller, for the 18"), which is weird to me. It could be though.
      01-19-2016, 04:24 PM   #72
itrocks4u
Drives: F80, F36, E90
I test drove both. I have the xdrive. yThe difference is minimal for daily driving. On wet roads xdrive slides. xdrive is like RWD with nannies. If you try to misbehave too much, she'll put you straight... I wanted RWD but Canada did not offer one.
      01-19-2016, 04:32 PM   #73
ynguldyn
What's that about E90s? We're talking about F30 sizes, which are one step up in the circumference required, when compared to E90, just like everyone else has said.
      01-19-2016, 04:46 PM   #74
BavarianFanatic
Too much is never enough
Drives: Too Many
Cheers
There is no issue whatsoever running a tire that is 3% taller (or shorter) than stock so long as you run the same size on a given axle (or all four corners if AWD). The only side effect would be an error in indicated speed. But, since BMWs are calibrated with an optimistic bias, you may actually be making the indication more accurate.
Your second comment about that 5% delta in aspect ratio is losing sight of a key bit of information in the post you quoted - he's referring to his WINTER tires. Your comments are wholly redundant. I'll also add that, on public roads, you'll be hard pressed to find anyone that is able to discern any measurable difference in handling, braking, or feel if comparing a 45 series tire with a 50 series tire of the same section width and model.
It's great that you're such an expert, but you should probably refrain from offering opinions as fact unless you have data to back up your claims. Related, having read something on the internet does not make you an expert.
Cheers
      01-19-2016, 04:49 PM   #75
stvding
stvding's Avatar
Drives: G20 M340ix
Never use all season in winter no matter what kind of drive u have!!!!awd is just for accelerating fast. Huge mistake not having winter tire
      01-20-2016, 09:36 AM   #76
Outlaw 06
Outlaw 06's Avatar
Cheers
You clearly understand the concept...
My square 17x8, 225/50 R17 winter set-up on my 2013 F30 328i.
Last edited by Outlaw 06; 01-27-2016 at 04:35 PM.. Reason: Added photo of 17" winter wheel/tire set-up.
      01-20-2016, 07:12 PM   #77
Firaxis
Drives: Car
I tried both a 330D RWD and a 335D Xdrive (both 2015) and TBH I really couldn't tell much difference.
Between some previous cars I had it was night and day, between the Beemers not much in it.. The biggest thing to note was power delivery between the two engines.
I suppose if track days are your sort of thing then go for the RWD to get the tail out, apart from that choose whatever's cheaper / your happy with.
      01-20-2016, 08:50 PM   #78
uansari1
Drives: 2016 BMW 340i xDrive
Cheers
OEM size is 225/45-18. You are wrong.
The 225/50-17 is the correct size and what I'm running for my winters. TireRack's website also suggests this size.
      01-20-2016, 11:23 PM   #79
Blubaron79
Blubaron79's Avatar
Drives: 2021 M340i xDrive
I tested the 4 series before it was released. We drove them on the track for the day. The only difference was the xdrive had all seasons. The xdrive would slide a little more in the corners probably only because of the tires. Just make sure you get the sport set up with DHP and Summer's on your xdrive
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive
      01-21-2016, 03:15 PM   #80
stvding
stvding's Avatar
Drives: G20 M340ix
Don't
