06-14-2018, 05:09 PM | #23 | |
Rep 10,473
9) Memory position. Just as seats return to set position with memory 1 or memory 2 button, mirrors do the same. Option 459A on your VIN check. Shadowline? Option 760A? Those are the options you need to be aware of for replacement. |
06-15-2018, 04:38 AM | #24 | |
New to this! Help me!
Rep 12
I've checked my VIN options now. So it turns out: Autodip. No. (but interior mirror does have it) Memory position. No. Shodowline. Yes it seems. I've attached the full list below: L812A National version England / Ireland P337A M Sports package S1CAA Selection of COP relevant vehicles S216A Hydro steering-servotronic S230A Extra package, EU-specific S258A Tire with run-flat functionality S2PAA Wheel bolt retainer S2PEA BMW LA wheel M Star Spoke 400 S2TEA Automatic transmission w/ shift paddles S2VBA Tire pressure display S302A Alarm system S3DEA Omission of specific design scopes S423A Floor mats, velours S428A Warning triangle and first aid kit S431A Interior mirror with automatic-dip S481A Sports seat S493A Storage compartment package S497A Centre armrest, rear S4FTA Alu, brushed, high-gloss black accent S4NEA Blow-by heater S508A Park Distance Control (PDC) S521A Rain sensor S534A Automatic air conditioning S544A Cruise control with brake function S563A Light package S575A Supplementary 12V sockets S5A1A LED Fog lights S5A2A LED headlight S5DAA Passenger airbag deactivation S606A Navigation system Business S654A DAB tuner S698A Area-Code 2 for DVD S6ACA Intelligent emergency SOS call S6AEA Teleservices S6AGA eDrive services S6AKA Connected Drive Services S6AMA Real-Time Traffic Information S6NHA Hands-free with USB interface S6WAA Instrument cluster, expanded equipment S6WAA Instrument cluster, expanded equipment S704A M Sports suspension S710A M leather steering wheel S715A M Aerodynamics package S760A High gloss shadow line S775A Headlining anthracite S850A Dummy-SALAPA S853A Language version English S880A On-board vehicle literature English S8KAA Dummy-SALAPA S8R9A Refrigerant R1234yf S8S2A Coding alarm signal S8S3A Automatic locking when driving off S8SMA Car ident. number visible from outside S8TGA Thiefproofing device |
06-15-2018, 04:56 AM | #25 |
Rep 12
So I've taken a couple of photos. Here's how it looks without being held upright by tape. What appears to be scratch marks is just residue from the sticky tape. (photo 1)
I've circled the part that has sheered. (photo 2) I also took the mirror apart to attempt to find the part number (photo 3), but I'm still none the wiser what the part number is, I assume it is the number on the sticker, but coming up with nothing searching for this. Also I'm baffled by searching for the part after put my VIN number into a parts search, I came up with at least 100 different options of wing mirror, none of which seemed to match up with the number on the sticker... |
06-15-2018, 07:12 AM | #26 |
Rep 12
Ok, I took the door card off and removed the mirror. It’s definitely 6 pins. I’ve bought a second hand one off eBay from a 2013 330d, which I’m hoping will be here tomorrow. Guy selling is confident it’s just plug and play and should work just fine. It’s a different colour, so i’ll need to swap the top section over, but that shouldn’t be a big deal. Just hope all the electrics still work with the replacement.
06-15-2018, 08:00 AM | #27 | |
Rep 10,473
https://www.ebay.co.uk/itm/BMW-3-SER...cAAOSwYK1bErcm This is to late to help you but I believe the Part Number is 51167345660. No hits on that piece on eBay in EU. But in case the one you purchased doesn’t work out, this search term with “used” and “UK” should limit your choices down to under 50. bmw (f30,f31,316,320,325,328,330,335,340) -(e30,e36,e46,e60,e63,e70,e90,e91,e92,ne92,e93,f01, f20) mirror -(03/,1992,1995,1999,2000,2001,2002,2003,2004,2005,2007 ,2008,2009,2010) -(compass,control,glass,interior,left,motor,passeng er,rear,rearview,switch,vanity) -“5 pin” If still no success, broaden search search term to this, combined with “used” and “EU” and your choices are expanded to around 100. bmw (f30,f31,316,320,325,328,330,335,340) -(e30,e36,e46,e60,e63,e70,e90,e91,e92,ne92,e93,f01, f20) mirror -(03/,1992,1995,1999,2000,2001,2002,2003,2004,2005,2007 ,2008,2009,2010) -(compass,control,glass,interior,left,motor,rear,re arview,switch,vanity) -“5 pin” You need to ask seller if Shadowline or for VIN of donor vehicle and check yourself if they do not know. Last edited by IK6SPEED; 06-15-2018 at 08:18 AM.. |
03-28-2020, 11:18 PM | #29 |
Rep 42
Sorry for the thread resurrection - a lorry with an insecure side curtain kindly smashed into my o/s wing mirror punching a hole in the mirror cap which I can sort however it has also damaged part 4 in the diagram on page 1.
Can anyone tell me if part 4 can be replaced on its own or is it part of the whole shooting match?? Si |
07-26-2020, 06:55 PM | #33 | |
Rep 572
Shouldn't be a problem. These instructions will help if you fancy having a go yourself. Just be careful when removing the glass. https://www.newtis.info/tisv2/a/en/f...les/1VnYCfz455 https://www.newtis.info/tisv2/a/en/f...soles/GxVcVmQ8 https://www.newtis.info/tisv2/a/en/f...soles/GxZfXlW2 |
08-01-2020, 10:26 AM | #34 |
Rep 12
They should be able to replace that part only, but when I enquired about mine, they wanted to replace the whole unit. My advice would be to buy a second hand one off eBay and fit it yourself. Much much cheaper and wasnt too difficult, even for me.
330e, f30, mirror replacement, wing mirror |
