08-09-2020, 10:42 AM | #1 |
Rep 22
Is this a leaking driveshaft?
Hi all,
I have a 2013 320i xDrive. I noticed what I thought was a possible leaking driveshaft seal, but after a closer look I'm not so sure. This view is looking through the front passenger wheel (on a right hand drive car) at the drive shaft. You can see the dark buildup of grime which I thought was a seal leak but after touching it, it doesn't feel fresh, just feels like a build of old grime. You can see the consistency in the photo on my finger. Any opinions on whether this is a leak? I did have the front diff fluid changed when I bought the car (around 6months ago) and the mechanic didn't mention this. Any opinions appreciated. Thank you Last edited by mjgreen81; 08-09-2020 at 12:24 PM.. |
08-09-2020, 12:02 PM | #2 |
David
786
Rep 2,009
Output shaft seal on the differential.
It does look like a very slow weep vs a leak based off the build up like you said.
08-09-2020, 12:22 PM | #3 |
Rep 22
If it is just a weep, does it still need replacing? If yes, does it need immediate attention or can it wait until it's in the garage for other work?
08-09-2020, 12:25 PM | #4 | |
David
786
Rep 2,009
I went to a shop and they charged around $600 for both sides. If your fluid is clean and at the proper level this weep won't affect it at all. Most people wouldn't even address it.
driveshaft, f30, leak, xdrive |
