08-19-2018, 11:06 AM | #1 |
Rep 32
Carly vs esys coding
I used to have an e91 and used a cheap obd WiFi adapter to do a bit of coding with Carly app. Plugged it in to f31 I now have and it refuses to do anything
Question is, do I spend £12 on an esys cable and learn what to door spend £50+ on the dedicated Carly adapter and have the easiness of that? Is esys coding all VO and in German? I worry I would break something with it. Last edited by Fantastic; 08-19-2018 at 12:01 PM.. |
08-19-2018, 11:26 AM | #2 |
Regular user
224
Rep 965
Drives: F30 330D M-Sport Auto
Try downloading the free version of the Bimmercode App. It lets you test your adaptor works in the car before paying for the App.
08-19-2018, 05:14 PM | #3 |
Rep 147
Buy a WiFi vgate adapter for 16 usd and get the Bimmercode phone application which is free on the app store & play store, but in-app cost to enable coding is 30 euros. Cheapest option I found and Bimmercode is actually really good, especially with the expert mode option. Supports F3X models.
Last edited by Lagemba; 08-19-2018 at 05:17 PM.. Reason: Supports iPhone & Android |
08-20-2018, 02:09 AM | #4 |
Rep 476
I went for the Vgate and Bimmer code. About £35/40 all in. Works a treat, can make all the changes i'd want too..
F25 X3 35d - F30 335i - |
09-06-2018, 06:40 AM | #6 |
Rep 9
I got the vgate wifi obd adapter but Bimmercode times out during initial loading. Adapter works fine with other apps that work with obd. Like carly. Any ideas?
09-07-2018, 06:06 AM | #7 |
Rep 777
I got the Vgate4 adapter checked with Bimmercode for recommendations and this is the one they recommended, the adapter is Bluetooth not wifi and works a treat no dropouts and very stable connection
09-07-2018, 06:15 AM | #8 |
Rep 147
I'd get the vgate obd 2 WiFi adapter for £15 and then download Bimmercode and activate coding for £30. Very worth it and is compatible with all F3X models. Spent 3 hours coding stuff into the car with expert mode because there are so many options.
09-07-2018, 06:17 AM | #9 |
Rep 1,054
09-07-2018, 06:23 AM | #10 | |
Rep 147
If you could provide the actual error code you're getting when trying to connect, would help diagnose your issue. |
02-07-2022, 07:32 PM | #11 | |
Rep 1
Que versión del Vgate funciona con el Bimmercode?
02-08-2022, 04:15 AM | #12 |
Rep 1,475
This one works with Bimmercode
https://www.amazon.co.uk/Bluetooth-A...dp/B07SQLY39V/
