BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Help Coding M4 adaptive headlights into a 435i
proTUNING Freaks
      07-18-2021, 01:36 AM   #1
DannyM235
DannyM235's Avatar
Drives: BMW F22 M235i
I was wondering if anyone knows how get a set of M4 adaptive headlights to work on a 435i that came with adaptive headlights. I recently acquired a 2016 435i at auction and I am rebuilding it. It came with adaptive headlights from the factory, but because it has front end damage the headlights did not come with the vehicle. So I purchased a set from another forum member here about a week ago off an M4. Yet, when I went to install them today the low beam works and so do the turn signals, but I'm getting an adaptive headlight error on the idrive system and the high beams don't work, nor do the angel eyes. I tried doing some coding via BimmerCode by changing the settings to LEDs, but it didn't seem do resolve the issue. I am wondering if anyone knows of a professional who does remote coding or if someone knows how to resolve this issue, any help would be much appreciated.
      07-18-2021, 03:44 AM   #2
atzebmw
Drives: Tesla Model 3
You need E-Sys for that and then you will find many instructions here in this forum.
      07-18-2021, 07:41 AM   #3
DannyM235
DannyM235's Avatar
How do I go about getting E-Sys and can I run it with my cellphone or old MacBook Pro laptop?
      07-18-2021, 08:49 PM   #4
DannyM235
DannyM235's Avatar
Ended up purchasing a Schwaben Multi-System Elite Scanner from ECS tuning today. I'm hoping I can code in the modules to work, the rep from ECS told me I could do coding with it, so I'm hoping I can get this issue resolved soon.
https://www.ecstuning.com/b-schwaben...020sch01a~scf/
Anyone know if this scan tool can code headlight modules
      07-19-2021, 02:44 AM   #5
atzebmw
This tool can't code and this tool doesn't even fit your car.
      07-19-2021, 03:43 AM   #6
DannyM235
DannyM235's Avatar
I just checked the site and it states it works for both the 2016 435i that I'm rebuilding and also my 2016 M235i. I guess I'll have to call and cancel the order in a bit once they open. It list the following in the product description. I bolded and put the part in red which is the reason I purchased it.
Product Details
New 2020 Edition
Schwaben Multi-System Elite Scanner is a unique tool that delivers OE-level diagnosis for different car brands and supports the most commonly required service and coding features. Through hardware and software upgrades, technical staff and enthusiasts can now approach problems with greater speed and accuracy.
- Works with the latest 2018/2019 models, also works on 1987 to current models
Works on all OBDII/EOBD compliant vehicles
Newest features include
BMW/MINI updated firmware is now compatible with the BMW/MINI F series.
Loads faster and finds troubles more accurately and quickly.
New color screen for easier reading.
Gets access to trouble codes and freeze data of powertrain, chassis and body systems
- Auto Scan function scans vehicle systems in just seconds
- Shows live vehicle sensors data in text and graph formats
- Merges interactive live sensor graphs
- Records and playbacks data-logs to catch intermittent failures
- Retrieves ECU information
- Runs component/system bi-directional tests
- [COLOR="DarkRed"]Supports advanced functions such as adaptations and control module coding[/COLOR]
- Supports the most commonly required service features like steering angle sensor (SAS) calibration, DPF regeneration, ABS bleeding, BCM/SIR setup, etc.
- Upgradable to cover more car makes at unbeatable value
- Multi-language menus and codes for an international marketplace
- Extremely easy to use with clearly arranged keypad, menu-driven operation and shortcuts
- Ergonomic design and ruggedly built for both shop and road tests
- Can reset most batteries but cannot change battery load setting or convert from AMG to Lead Acid at this time or vice versa. Possible in the future with software updates.
      07-19-2021, 04:08 AM   #7
atzebmw
Yes, you are right.
I only read model E46 at the bottom and thought this is only for old models.
But unfortunately it still cannot code.
      07-19-2021, 04:18 AM   #8
DannyM235
DannyM235's Avatar
Yes, you are right.
I guess I'm going to have to cancel the order before they ship it out today because I paid for expedited shipping. I don't know why the ECS running rep told me I could program the headlight modules if it's not possible. I looked into getting E-SYS but don't know how to go about it because I don't own an old windows laptop. I only have a old 2010 MacBook Pro laptop that I have upgraded the HD and Ram, which I currently use for school.
      07-19-2021, 05:17 AM   #9
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
Get a Windows VM on your Macbook and order an ENET cable - I can probably assist you remotely.
No massive software installs needed to code remotely.
      07-19-2021, 10:48 AM   #10
DannyM235
DannyM235's Avatar
Would that mean I need to get Parallels or VMware Fusion to make this work or do you happen to know how I can get Windows VM without either? What would I need to get to be able to have you help me code it remotely?
      07-19-2021, 11:34 AM   #11
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Drop me a PM
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube
      07-19-2021, 05:44 PM   #12
DannyM235
DannyM235's Avatar
Anyone know who does remote coding
      07-19-2021, 08:29 PM   #13
DannyM235
DannyM235's Avatar
Ended up contacting bimmertech hopefully they can get this going for me
      07-19-2021, 11:02 PM   #14
4x4kiwi
Drives: 2012 BMW Active Hybrid 3
Wibbles. Your PM space allocation appears to be full. David
      07-23-2021, 03:41 AM   #15
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Cleared some space
