12-24-2021, 07:56 AM | #1 |
Rep 275
F36 440i with Adaptive suspension - M sport springs?
Hi,
I swapped from an f36 430i with "static" msport suspension, to an f36 440i with adaptive. I feel like the 430i had far stiffer springs, both in terms of cornering flatness and also front end lifting under acceleration etc, and believe the adaptive suspension has softer springs? Has anyone here tried fitting the standard msport springs to the adaptive dampers? Thanks! Tom.
Previous: 2002 E46 330i M-Sport (m54b30 LCI), 2007 E92 335D M-Sport Coupe (m57), 2003 z4 3.0i (m54b30), 2010 E92 325D M-Sport Coupe (n57 LCI), 2019 F36 430i M-Sport Pro Gran Coupe, 2018 F36 440i M-Sport Pro Gran Coupe MPPSK
Current: MY2021 M550i, Aventurin Red, Ivory Nappa, Comfort Pack, Tech+ |
12-25-2021, 09:58 AM | #2 |
Rep 10,272
BMW OEM springs for 440i with M Adaptive suspension are designed to reflect additional weight plus adaptive shock performance characteristics.
In this case, practical experience with other springs may matter more. Search this sub-forum for ACS springs + adaptive. Many useful threads to review. |
12-25-2021, 12:31 PM | #3 |
Rep 4,358
i recommend skip the m-sport springs and just get Eibach Pro-Kit springs, tested with factory dampers
https://eibach.com/us/1946/E10-20-03...-Coupe-pro-kit . Last edited by alohasurftoad; 12-25-2021 at 01:02 PM.. Reason: changed link for correct vehicle |
cfm56d7b5899.00 |
12-27-2021, 05:54 PM | #4 | |
Rep 10,272
01-06-2022, 10:38 AM | #5 | |
Rep 275
also, would you change to the f8x bumpstops at the same time?
01-06-2022, 11:07 AM | #6 | |
Rep 4,358
I believe Eibach has two different Pro-Kits. the rear springs are the same however in one kit, the front is a bit lower. not sure about ACS. please do your own research regarding all of this info prior to purchase. . |
01-07-2022, 11:20 AM | #7 |
Rep 275
hmm. Birds have offered me a test drive of their 435i with their suspension set-up.
Wonder if anyone local has eibach or ACS springs only on adaptive dampers, it'd be about £1000-1500 cheaper than going the whole hog with new dampers too, I want to know what the return on that looks like....if the eibach springs fixed 90% of the problems then that could be enough for me...
01-07-2022, 01:53 PM | #8 | ||
Rep 1,649
I am currently running the stock adaptive shocks with a set of F80 MT springs and F80 bump stops. It's pretty good for street and a little fun on the back roads. I still wish the comfort setting was a tad more dampened and sport slightly less, but all in all, not bad. I would say the drop from rwd m sport height was about 1/4". |
