10-13-2020, 10:49 AM | #1 |
Rep 102
shakes after changed Spark Plugs and Coils
I changed all 6 plugs and Coils. Replaced with OEM plugs and Eldor Coils. There is no check engine light.
Realize when cold start that I start my car, the engine shakes for like 5 seconds and disappears. When on the highway, I floored it and I felt the engine shakes a little. I didnt feel it before the tune up. I have 70,000 miles on my F30 now. Is there any test I can do?
F30 335i xdrive
10-13-2020, 11:16 AM | #2 |
Rep 40
Similar thing happened when I changed them too.
I think check for any codes and either reset adaptations or wait and let the car adapt. Did you double-check the gaps when installing? |
10-14-2020, 05:13 AM | #3 |
Rep 923
If you did the plugs yourself and it was your first time, 'maybe' a plug is a little loose? The torque is so low...it barely seems enough to me...but I know our plugs are delicate.
Read your codes, even though you don't have a CEL, you may show codes that will help you diagnose your issue. If you didn't have the issue before and all you did was plugs and coils, I suspect you'll find a code pointing to a particular cylinder. BTW, if you are stock, the OEM plugs will be gapped already. If you're tuned, you would need a particular plug and/or to gap them.
