10-17-2020, 11:52 PM | #1 |
Rep 102
New Brembo brakes and rotors
I just changed my front and my rear rotors and brakes to Brembo.
See the gaps and the touching points. The rear looks like my brakes is cutting my rotors. Is that normal? I asked my mechanic to grease the guide pins, how can I check on it?
F30 335i xdrive
10-18-2020, 12:44 AM | #3 |
Rep 417
10-19-2020, 08:56 AM | #5 | |
Rep 417
In terms of sliding pin, you will have to take it out to check. They are covered by plastic caps, you need a 8mm allen head to remove it. |
10-19-2020, 06:33 PM | #6 |
Rep 206
That first picture of your rear pad/rotor does not look right. The pad should not be grinding up the inside edge of your rotor like that. Hard to tell if the pad isn't seated right, is wrong, or there is something odd with the rotor, but something isn't right there...
Last edited by rphz; 10-19-2020 at 09:21 PM.. Reason: Edit to clarify: inside edge of rotor |
Wires1636.50 |
10-19-2020, 07:06 PM | #7 |
Rep 102
Let me check both sides tomorrow again. looks like pressing too hard on a edge
F30 335i xdrive
10-19-2020, 08:29 PM | #10 |
Rep 1,934
It's normal. There will be a tiny untouched section on the outside diameter and then a much larger untouched section closest to the rotor hat. No brake state will get too close on either side.
10-19-2020, 09:30 PM | #11 | |
Rep 206
10-19-2020, 10:19 PM | #12 |
Rep 102
got 2 more pictures, and 1 is similar with different view. Other is other side
The material buildup is like chips. I check out tomorrow
F30 335i xdrive
10-20-2020, 08:21 AM | #14 |
Rep 4,842
I have the blue Brembo m-sport rotors + EBC red pads, and for me, the rear pads have a slight gap (~1/32") between the edge of the pad surface and that hub radius that you are dragging on.
It looks like the rotors are slightly larger than the calipers were meant to be married with. |
10-20-2020, 04:55 PM | #15 |
Rep 833
Drives: BMW F36, E36, E93
Wich pads did you buy for the rear is it one of these numbers?
P 06 072 P 06 087
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
10-21-2020, 03:33 PM | #16 |
Rep 102
I got the ceramic: Front Ceramic P06088N rear ceramic P06072N
I was work from home the last few days and didn't drive much. I came to the office which is about a good 50 mins drive each way and will see tomorrow with any differences. I checked yesterday, It is sitting right. Since the rear is smaller, so looks like its pressing on the rotor more. Will update pictures tomorrow
F30 335i xdrive
10-22-2020, 03:42 PM | #17 | |
Rep 833
Such Fun
10-22-2020, 04:28 PM | #18 | |
Rep 206
10-25-2020, 05:46 PM | #19 |
Rep 102
I got these.
Front Rotor 340mm (09.C398.13 Drill/Slot) Rear Rotor 330mm 09.C117.11 After driving for about 100 miles looks good now. There is a hollow space and the brakes pads aren't falling down into it. The cut is not that obvious now.
F30 335i xdrive
10-25-2020, 08:57 PM | #20 |
Rep 833
Yes agree, right pads with the right rotors, should be all fine.
Are you happy with the braking experiance?
Such Fun
10-26-2020, 07:18 PM | #21 |
Rep 102
This is ceramic which is louder than OEM which has the grinding sound. As for braking, I don't know if I changed the brake fluid that causes at 2/3 it starting to brake hard instead of steping around 1/3. Obviously the braking is slightly more.
F30 335i xdrive
10-27-2020, 03:00 AM | #22 |
Rep 833
I was not talking about the "X" version of the Brembo pads. I put the "normal" ones in and there is no noise at all for the last 30000 Km.
Such Fun
