01-09-2022, 11:28 AM | #1 |
Rep 103
Hello guys, looking for your help and advice.
I have a bmw f30 N26 72K miles. The last 2 years my car shakes in the morning when I start it up when its below 50 degrees, after 10 mins of running shaking goes away but still doesn't run as smooth as it used to. I have changed spark plugs and scanned the computer no check engine light and no codes come up. What could it be? Any ideas? |
01-09-2022, 12:16 PM | #2 | |
Rep 10,255
10 minutes is a long time for a code not to be produced. While remote diagnostics are very difficult at best, all components which participate in creating the right fuel mixture would be the first area to examine. |
01-09-2022, 12:25 PM | #3 | ||
Rep 103
01-10-2022, 06:31 PM | #8 |
Rep 103
Thanks for the reply guys. What you mean by fuel problem what could it be?
I was thinking also could it be engine mounts? Because I do have drivetrain vibration sometimes when I drive the car, the power is not as smooth as it used to be? |
01-24-2022, 11:33 AM | #10 |
BMW CCA 69606
86
Rep 227
Run the scan while engine is running poorly. Do not wait until you shut the engine off.
Leaking fuel injectors can put fuel in cylinder after engine is off, causing rough running on the next start. Anything unusual about the color of the plugs you changed? Last edited by pshovest; 01-24-2022 at 04:56 PM.. |
