01-06-2018, 10:42 AM | #1 |
Rep 1,862
Drives: powered by bootmod3
bootmod3 update - Additional and **FREE** OTS maps for N55-EWG (Stage 0+ M2)
Hey guys, quick update on something new we've added and changed for all BM3 users. OEM M2 map is really great learning maps on how to self-tune your N55-EWG cars with BM3. Other than boost control all of it applies to N55-PWG cars too. People often ask about details on it just like the CS and GTS maps on the M4, how they work, what are the differences in tuning, what did BMW change that makes them make more power, etc. You've all seen dynos which show decent gains over the OEM N55 EWG software. Some of you also wouldn't mind trying it on your N55s just to see what the fuss is about
We had the Stage 0+ (M2) map as an OTS map for a while now but it required 1 additional map credit ($50 on the N55) to use. We've now made that map 0 credits worth (free) At this point bootmod3 license cost includes this additional map along with any other OTS map that is worth 1 map credit. We're adding in another change to be able to import either of these Stage 0+ maps into your own map for your own learning/curiosity sake |
01-06-2018, 11:14 AM | #2 |
Rep 1,291
Nice - i was actually wondering about that, also how the M2 was generating burbles that are not gunshots and compatible with a catalyzer.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
FSociety3812.50 |
01-06-2018, 11:20 AM | #3 |
Head Fry Cook at McBurgertown
507
Rep 1,005
2015 F32 N55
proTUNING Freaks
1. Would the M2 map change the hp/tq values on the sport gauges in the same way that the MPPK tune would? 2. Can BM3 be loaded using OBDII without tripping the flash counter? |
Chicken_Joe606.00 |
01-11-2018, 12:27 PM | #5 | ||
Rep 1,862
2) More on BM3's obd unlock very soon! No, its an OEM file but the end user adjustability screen will let you toggle it and reflash to turn it off. |
01-11-2018, 12:55 PM | #6 | |
Rep 1,499
01-11-2018, 02:42 PM | #8 |
Rep 1,499
BM3 already has an app for iOS. I'm running it on my iPhone 7. Works well!!
01-11-2018, 02:55 PM | #9 |
Rep 969
PTF/BM3 FTW!!
01-11-2018, 11:34 PM | #10 |
Rep 258
I cannot wait for the obd unlock for bm3. Been holding off still using jb4 for a while now, but I'm ready for some change and with all the easy unlocking thru obd2 now, I'm ready! I know this question doesn't really pertain to this thread, but if I have mppk on my car, will there be a stock mppk map that I flash back to or does it flash to stock without. Mppk?
FSociety3812.50 |
01-25-2018, 04:15 PM | #11 |
IG @bmwF9xG80
3813
Rep 7,593
Tried M2 map on my car def huge improvement over my stock map :-D
*Full Tank of Gas* 4.78s Stock w/ Bolt-Ons 4.49s M2 map w/ Bolt-Ons (Same Day) 4.3s OTS Map ;-) 1/4 mile *full tank* 12.98@100 stock 13.04@106 stock run #2 12.8@107 M2 12.5@111 OTS 4495lbs big boy N55 here
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 01-25-2018 at 08:03 PM.. |
02-05-2018, 03:13 PM | #12 |
Rep 832
Drives: 2019 G01 X3
How does the Stage 0+ compare to the OEM MPPK?
02-05-2018, 03:22 PM | #13 |
Rep 969
Look at post above you for actual results/times. I'd suspect Stage 0+ is probably close to OEM MPPK power wise.
02-05-2018, 05:35 PM | #14 |
IG @bmwF9xG80
3813
Rep 7,593
STG 0+ in our case is the OEM M2 Calibration which is more than OEM MPPK but also less than OTS map
I ran it, it was bad ass! Give it a try
DragonGate71.50 |
12-06-2018, 05:12 PM | #15 | |
Rep 30
Thanks! |
12-06-2018, 10:58 PM | #16 | |
IG @bmwF9xG80
3813
Rep 7,593
STG 1 as well
12-06-2018, 11:43 PM | #17 |
Rep 283
Does the M2 also have the chargepipe issue the other "lesser" N55s have? Also if I were to flash the car, I'd there a way to lock the dme after flashing stock for service and warranty reasons?
2014 F32 435i /// M Sport Brakes /// Vorsteiner VFF103 /// Resonator Delete /// MP Carbon Front Spoiler /// MP Carbon Mirror Caps /// MP Carbon Rear Spoiler
@slowf32 on instagram |
12-08-2018, 04:13 PM | #18 | |
Rep 54
When you flash back to stock you can choose to re-lock the DME or leave it unlocked. However, if they check the flash counter it will be detectable. |
12-10-2018, 12:01 PM | #19 | |
Rep 30
The bootmod3 rep said there is no limit to how many times DME can be flashed and that there is no flasher counter that will tell how many times DME was flashed. bootmod3 rep did confirm that the stock map can be reflashed and that DME can be relocked but also added that DME relocking or stock map reflashing does not prevent the dealer SA from detecting DME flashing even if stock map was reflashed. So DME re-locking or stock map flashing is appears rather useless a feature especially for warranty claims. Now, with only 30K on my 435i and knowing this will likely get by VIN flagged, I am on the fence on whether I should go for it at all But again, the money on the bootmod3 license has been spent already... so... Last edited by dor1angray; 12-10-2018 at 01:48 PM.. |
12-10-2018, 12:56 PM | #20 | |
Rep 1,499
The flash to stock and lock isn't necessarily useless. It's great because at first glance the car will appear to be stock. Only if the dealer does extensive digging will they find evidence of a flash tune. Either way, if you have a good report with your SA at BMW you shouldn't have any issues. My SA knows I'm FBO + tune and I get regular maintenance and warranty items covered with no issue.
12-10-2018, 01:47 PM | #21 | |
Rep 30
To my question on what map I should flash while still being on OEM without any upgrades, Stage 1 was recommended. What do you mean charge pipe was blown off? Like physically blown off while driving? Can this happen on Stage 1 with 435i OEM equipment and if so what can be done to prevent this? Sorry about noob questions, still pretty new to the tuning world. Thanks! |
12-10-2018, 02:01 PM | #22 | |
Rep 30
Thanks for your response. I guess YMMV as it comes to the service adviser. I have ready some post here presumable belonging to one of those service advisers. They guy claimed that they have no benefit in flagging VINs as they feed off warranty claims paid for by BMW and the more of those they have the better it is for the service center. So I understand there is a chance that going FBO will not get a 100% of SA's all freak out and start running in circles shouting the vehicle is now ruined and will not be serviced because by exhaust, air intake, and/or chargepipe are not OEM. I guess I will stop by at a couple of authorized BMW centers to check on those service advisers I had worked with and talk to them about the plan of going FBO to see how they will react. Another option is going to a tuning center (bootmod3 customer rep provided me with a link to the one they trust here in Miami) and talk to the folks to see if they can give me a reference or a name of the SA they know who is flexible enough. |
bm3, bootmod3 |
