03-23-2019, 01:09 PM | #23 | |
Rep 420
See here... https://www.autoexpress.co.uk/car-ne...en-to-use-them In particular this para... Fog lights are designed to be used when visibility is severely restricted, chiefly by fog, but also in other poor visibility conditions such as snow or heavy rain. They are designed to make you more visible, rather than helping to light your way so they are not needed in good visibility conditions at night - that’s what your headlights are for. They should only be used when your car's main lights won't be enough to make you visible to other road users. The Highway Code (Rule 226) states: "You MUST use headlights when visibility is seriously reduced, generally when you cannot see for more than 100 metres (328 feet). You may also use front or rear fog lights but you MUST switch them off when visibility improves." |
03-23-2019, 01:50 PM | #24 | |
Rep 1,470
03-23-2019, 03:36 PM | #26 | |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
The cornering light on the 220d Active Tourer with Adaptive LED headlights are brilliant though as it uses an LED unit within the headlight and they are bright and light up the corners
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
03-25-2019, 07:04 AM | #27 | |
Rep 44
03-25-2019, 12:58 PM | #28 | ||
Rep 2,511
LCI fog lights seem to have two light units in the cluster. I assume one fog and one cornering.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
03-25-2019, 03:16 PM | #29 |
Rep 468
They were enabled from factory in my car. Led Headlights.
Initially I did code them out as I thought it looked silly ( with bimmercode) After seeing so many cars on the road with the same feature, I re-enabled them . I do think the help to brighten the corners when turning. At least in my car.. |
03-25-2019, 04:28 PM | #30 | |
Rep 420
