03-24-2019, 11:07 AM | #1 |
Rep 5
Bimmertech pp82dsp harness/channel documentation
Hi All,
I'm in the middle of audio upgrade on my 2019 F36. Already replaced stock amp with pp82dsp and now waiting for sub and second amp to arrive. One question has been on my mind as I plan for the sub amp wiring: which channels on the 82dsp actually go to which speakers? The manual sucks and does not represent state of things. As far as I can tell here is how the harness is wired: Channel A: Front 4" mid and tweeter (most likely there is a passive 6db or 12db crossover inline). Don't know if left or right. Channel B: Front 4" mid and tweeter (most likely there is a passive 6db or 12db inline crossover). Don't know if left or right. Channel C: Rear 4" mid. Don't know if left or right. Channel D: Rear 4" mid. Don't know if left or right. Channel E: Center speaker Channel F: Unused? Channel G: Underseat 8" sub. Don't know if left or right. Channel H: Underseat 8" sub. Don't know if left or right. The above could be completely wrong, but I'm pretty sure the amp does not use a separate channel for the tweeters and instead uses it for center speaker. Secondary question: if channels G and H are used for underseat subs, is the line out on channel G & H also working so I can power the external sub amp? Manual says OR but like I said, manual sucks. Thanks a bunch. Rafael |
03-24-2019, 02:06 PM | #2 |
Rep 1,905
I believe if you connect laptop running the AudioTech-Fisher tuning software that will answer your questions. Each channel is identified and you can turn each on/off via software to double check.
Subs are mono, right? So L/R not a concern Good luck/Bill |
03-24-2019, 02:23 PM | #3 | |
Rep 2,180
You can use the Balance and the Fader in the iDrive, or mute channels in the PP82DSP to determine which speaker is powered by which channel. And you can always contact BimmerTech to answer your questions as your seller. No drama required.
03-24-2019, 06:16 PM | #4 | |
Rep 5
Thanks again. Raf Last edited by raf1hh; 03-24-2019 at 09:38 PM.. |
pp82dsp wiring diagram channels |
