10-21-2018, 04:13 AM | #1 |
Rep 56
ENET cable with LED
I have built myself an ENET cable, following instructions in this post:
https://f30.bimmerpost.com/forums/sh...71&postcount=1 It works perfectly. However, I would like to add an LED that indicate the activity, like others OBD2 cables / devices have. I know it is not so useful, but I would like it Could somebody explain how to connect the LED? |
10-21-2018, 09:07 AM | #2 |
Rep 16,082
To indicate activity you would not connect an LED directly, it would have to be interfaced with a driver. The only direct connection possible would be to the + voltage and ground pins, which would show that the car ignition is turned on, but you don't need an LED to know that.
10-21-2018, 11:28 AM | #3 |
Rep 878
Why bother, one of the important things when coding is to minimise power draw as much as possible, yes I know an led would be a tiny draw but it really serves no purpose. As you’ll know when it working and you get a connection.
enet, led |
