09-16-2021, 09:01 PM | #1 |
Rep 3
F30 2015 335 xi Vacuum cut out
Hello all, I need help.. I got this thing https://www.ecstuning.com/b-ecs-part...20923ecs01~dk/
Cut out vacuum actuated, I installed everything but I have a problem.. I can't get enough vacuum from the map, I got a boost tap on the map but it's not enough. Any one got a idea how I can do it.. Yes everything works fine we tried to open it with a vacuum pump. Thanks all |
09-16-2021, 11:18 PM | #2 |
Rep 7,597
How much vacuum does it need?
You are only going to have positive pressure post-turbo when under load and you aren't really going to ever have vacuum pre-turbo unelss you have a massive intake restriction... so the MAP isnt going to be a vacuum source when you need it. |
09-17-2021, 05:03 PM | #4 |
Rep 7,597
IIRC the highest vacuum i have ever seen pulled on the MAP is -0.7psi, whereas your cutout requires ~4 psi, and that's only at low/no throttle (i.e., idle or decel). If you want the cutout to open under WOT/boost, you are never going to get it to work by connecting post TB which you necessarily have positive pressure and not vacuum at the MAP under those conditions. A vacuum-actuated cutout is just not correct for this application with where you are trying to tap into
09-18-2021, 07:27 AM | #6 |
BMW CCA 69606
86
Rep 227
N55's have an engine driven pump that provides vacuum for the brake booster and evacuates the crankcase. Be sure your connection is reliable so you don't loose your brakes unexpectedly.
09-18-2021, 01:33 PM | #7 |
Rep 7,597
Yeah, but is this going to provide vacuum when he wants it and no vacuum when he doesnt want it? I am not entirely sure how this varies with engine load/rpm/etc
09-18-2021, 03:26 PM | #8 | |
BMW CCA 69606
86
Rep 227
EDIT: Scroll down the link to item 3. It's another $50 or$100. Last edited by pshovest; 09-18-2021 at 03:34 PM.. |
09-20-2021, 12:21 AM | #9 |
Rep 7,597
Gotcha, it just sounded like OP was trying to get this to open under vacuum at WOT, which is the opposite of what tapping into the MAP would do.
