12-04-2019, 12:05 AM | #23 | |
Rep 2,302
https://www.newtis.info/tisv2/a/en/f...m/search?q=A66 |
12-04-2019, 04:01 AM | #24 | |
Rep 162
Once again, thank you.
K Quote:
12-07-2019, 09:53 AM | #28 |
Rep 120
Hi atzebmw
I am hoping that you can guide me as well. On my 2016 model X3 F25 I keep getting Tyre pressure monitor (RDC) failure few minutes after startup. I have checked the tyre pressure manually and its perfectly fine. Online search suggested that it could be sensor battery issue but i can't seem to confirm that via Rheingold software. I read the fault codes using Rheingold and after doing the scan RDC is shown in RED colour under the Control Unit Tree section. Does it mean that the ECU for RDC is faulty? There are many fault codes relating to RDC which I am listing below S 0296 - No communication possible with Tyre pressure monitor D018EB - Message (RDC Tyre status. 280.0.8) missing, receiver ICM, transmiter RDC D018EA - Message (RDC Tyre status. 280.0.8) out-of-date, receiver ICM, transmiter RDC E114A0 - No message (status, tyre RDC 0x368) receiver KOMBI transmitter RDC E114A2 - Message (status, tyre RDC 0x368) not current, receiver KOMBI transmitter RDC I am bit lost here. Any advise on how to proceed with testing and changing the RDC sensors (if required) will be very much appreciated? |
03-19-2024, 09:54 AM | #29 | |
Rep 5
I receive the same error and i have tried with both E-Sys 3.40.2 and 3.30.x. Could you give me an advice on what i should try next? |
03-22-2024, 06:27 AM | #30 |
Rep 522
If ecu doesn`t belong to this car you will need to correct your fa.
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
03-26-2024, 02:19 PM | #31 | |
Rep 5
I did that first, now i can see it in the list when i read the FA. I also tried using full psdzdata, still no CAFD file found. It is not my first retrofit, i also did an electric towing hitch and paddle shifts, worked fine, but this RDC module i believe it is not from an F30, though the code matches on RealOEM. I have also found some info that suggests i should be flashing the ECU, as the RDC module does not have a CAFD file. |
