03-24-2017, 07:36 PM | #1 |
Rep 77
DIY F36 Screen 6.5" to 8.8" upgrade. Best Mod
Saw this upgrade from 2-Series post and finally bit the bullet to upgrade mine , 2015 F36 435.
Required - F3x 8.8 Screen , Got it used from eBay - T20-Torx , - OBDII Cable for F-Series https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 - E-SYS Software http://www.bimmerfest.com/forums/sho...d.php?t=631884 - Learn Coding yourself ( Youtube ) -------------------------------------------------------------------- First - make sure your system is compatible for this upgrade, easiest way is to look at your current iDrive display, if you have a solid red strip highlighting the select menu you are good to go , see here http://www.2addicts.com/forums/showt...1253651&page=3 Process is pretty simple. 1) Remove Trim 2) Remove 2 T20 Screw holding the screen 3) Disconnect cable from old display to remove ( tight space, use flat head screw driver to pry up the connect ) 4) Reverse the above process to install new 8.8" Screen 5) Code the car with below Only have to code these two entries to read HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display https://ibb.co/jvOwAa https://ibb.co/k6NCiv https://ibb.co/nfj3qa https://ibb.co/k0GSGF https://ibb.co/k13k3v https://ibb.co/fdkbAa https://ibb.co/fmEsiv https://ibb.co/fvi7GF https://ibb.co/ds21bF https://ibb.co/mEMuwF https://ibb.co/mjFMbF https://ibb.co/gsp3qa https://ibb.co/ctOUVa Last edited by fchen0125; 03-24-2017 at 07:42 PM.. |
03-25-2017, 09:43 AM | #4 |
Rep 77
03-25-2017, 09:44 AM | #5 |
Rep 77
03-25-2017, 11:45 AM | #6 |
Rep 163
Nice job. I agree, this is a good upgrade and relatively easy to do.
Careful buying an 8.8" screen as there is a difference between LCI and pre-LCI (both will work but pre-LCI on an LCI F30 will result in a blueish tint) - see more info here: http://f30.bimmerpost.com/forums/sho....php?t=1257854 |
03-25-2017, 07:24 PM | #7 |
Rep 190,805
Nice!
04-03-2017, 06:27 PM | #9 | |
Rep 77
I also read the non-full screen post before, I think it was referring to if you have the older version (No EntryNav) and did a direct swap |
04-03-2017, 06:29 PM | #10 | ||
Rep 413
04-04-2017, 09:19 AM | #11 | |
Rep 77
http://www.2addicts.com/forums/showt...1253651&page=3 Look at nelsdvn post @ 05-19-2016, 09:55 PM If you have red highlighted select background then YES, If you have red rectangular outline then NO |
duercos201.00 |
04-15-2018, 10:33 PM | #13 |
Rep 5
My car have display connector for one . But I bought the 8.8 screen from eBay have two connectors. What can I do? Thanks
Peter
bycomputer@hotmail.com |
07-09-2018, 05:14 PM | #14 | ||||
Rep 413
01-13-2019, 10:52 PM | #15 |
Rep 87
I’m getting the new obd cable and want to code the
8.8” screen as it is blank right now. I already know What to code but since I’m new to this I donno what menu option to choose from to code this using Esys. Sorry a newbie here. Thanks |
01-15-2019, 06:13 AM | #16 | |
Rep 332
Screen upgrade 6.5->8.8 HU_ENTRYNAV (or whatever head unit you have) 3000 DISPLAY_SIZE_RESOLUTION change 6.5_800x480 to 8.8_1280x480 3001 DISPLAY_VARIANTE change schmales_display to breites_display That's all! |
02-05-2019, 12:23 PM | #17 |
Rep 24
I’ve swapped out the screen on a 2017 F34 from 6.5” to 8.8” it’s ENTRYNAV2. The setting you would need to change is 3005 DISPLAY_PIP_CONFIG. CID DISPLAY set to 8.8 CID DISPLAY RESOLUTION 1240x480, DISPLAY VARIANTE=breites display. The other thing you need to change is the separate navigtion screen size otherwise it’s not in full screen. You can then use split screen which is fantastic. I will post some pictures shortly. The screen that you need is 6822626
05-06-2019, 03:23 AM | #18 |
Rep 67
Anybody knows the BMW number (?) or name of 2 screws Torx-20 that hold the screen?
I released them and one disappeared inside of a car, so meanwhile I want to order the new one. Thanks in advance, |
05-06-2019, 08:58 AM | #19 | |
Rep 332
Oval-head screw with washer 07149185673 seems to fit just about every F-series Push a rag into the gap BEFORE you start refitting! |
05-07-2019, 12:55 AM | #20 |
Rep 67
05-30-2019, 01:25 AM | #21 |
Rep 67
Hi again,
I already wrote in a different topic but maybe someone knows in this one. I have BMW F30 LCI with ENTRYNAV head unit (w/o navigation), bought from eBay and installed 8.8 LCI display (9387453). Coded it with two mentioned previously by topic starter codings and nothing happens. The screen is still black. I'm almost sure that technically it is working since The display seems almost brand new, no scratches, clean and additionally before I bought it seller provided image that it indeed works (I know that this can be different display but nobody will sell broken and say that it is working). |
05-30-2019, 04:20 AM | #22 | |
Rep 2,302
The NAV is the hint for the Navigation. Did you only change the display or the headunit too? |
