BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > CG Precision DS-1 Race Catted Downpipe - Now Fits 340i!
      03-03-2016, 06:07 PM   #45
CG Precision
CG Precision's Avatar
Drives: 2013 BMW 335i
Originally Posted by F80Boost View Post
How much power will it add to jb4 435i ?
Looks pretty but does it make power ?
Thanks! With a JB4 it will allow you to run map 2 which increases boost further. I'm not sure how much power the change in map has by itself, but with the catted DP you can expect up to about 20 hp and 30 ft-lbs. It is a great supporting mod with a tune.
Also if you didn't get your previous questions answered, we offer versions for the stock catback (3" connection) or we offer the 3.5" connection which only works with our catback exhausts. Compared with the factory DP, the catalyst is larger and far more free flowing as it utilizes a 200 cell per square inch (CPSI) metallic spun catalyst. The factory downpipe is 2 stage, 600 CPSI followed by a 400 CPSI ceramic catalyst.
      03-03-2016, 06:13 PM   #46
CG Precision
Qwk questions:
1. What is diameter of outlet on Turbo(exh) of my 2016 435i ? 3" ? 3.5" ? 4" ?
2. What is diameter of the oem downpipe connection at this point also?
3. What is oem diameter of downpipe (connection to exhaust) ?
4. Im not understanding if i have 2 connection points from oem turbo , and then oem exhaust ..... How can an aftermarket downpipe be larger ????
Isnt the factory connection spots, the "bottleneck " ????
Also, i guess your catalytic downpipe "flows" better ....???
Pm me cost plz...for factory (oem) connections , i have no exhaust.
Also,
What hp/torque will it add to my car :
2016 435i coupe F32/N55. JB4 Map 1, no intake, no exhaust.
Also, is it ok to add downpipe without exhaust ?
Your 2016 car has a 4" turbo outlet and 3" exhaust connection. You only get to remove the 3" bottleneck if you go with our catback too, but you can still use our DP with the factory exhaust as long as you order it with the 3" outlet flange. Even though you haven't increased the size of the exhaust after the catback connection, you will still see an improvement in performance because there is a larger unrestricted volume inside our downpipe. When you step on the throttle, the engine must create a pressure differential across the turbine wheel to spin up the turbo and make boost. By having a larger free flowing volume after the turbine wheel, the outlet pressure of the turbo is reduced, so the spool is improved. You can definitely feel, and hear, the difference.
      03-03-2016, 06:27 PM   #47
Mikli
Drives: G05F36F16F82E90E86E46E36E30
Could we expect to avoid the CEL without a tune?
      03-03-2016, 08:39 PM   #48
CG Precision
Yes, you can expect no CEL. It's a possibility, but based on our thorough testing you should ever get a CEL.
      03-04-2016, 12:47 AM   #49
Mikli
Pls PM with the best shipped price. Thks.
      03-04-2016, 03:58 AM   #50
F80Boost
Drives: Beater
how about the "exhaust/fuel" smell ?
is there any increase in smell ?
      03-04-2016, 06:08 AM   #51
cesare87
Drives: 435i
Now this had got my attention...
      03-04-2016, 06:57 PM   #52
dotjonnL
Drives: 335iX M-Performance
PM me price please?
Any sound clips? I have M perf exhaust, will it drone?
      03-05-2016, 12:44 PM   #53
CG Precision
PM sent....thanks!
      03-05-2016, 12:46 PM   #54
CG Precision
Nope. We have not noticed any difference in smell from factory. That's the beauty of using a large 5" cat.
      03-05-2016, 12:47 PM   #55
CG Precision
You'll love it. Just go to http://www.cgprecision.com/cms/index...egory=17975132
to place your order!
      03-05-2016, 12:48 PM   #56
CG Precision
Originally Posted by dotjonnL View Post
PM me price please?
Should not drone with M Performance exhaust. Even when running our 3.5" VS-1 system with the DS-1, we don't notice any drone at all, so I'm sure you wouldn't with the M-Performance.
PM sent.
      03-05-2016, 01:05 PM   #57
CG Precision
PM me price please?
Go to https://www.facebook.com/cgprecision/?ref=hl
We have a video or our VS-1 turboback on the dyno.
      03-05-2016, 02:04 PM   #58
Rennyk.
Drives: F10 M5
Sorry if this has been asked, if we go ahead and buy the down pipes now for the factory exhaust, if I decide down the road to install a new system that's not cg precision will it mate up with that system? Thanks!
2015 f10 M5
      03-05-2016, 02:09 PM   #59
CG Precision
Good question. Yes, if you order the DS-1 with the factory style connection, it will mate up with any system that uses the factory style downpipe connection. Most if not all other catback systems use the factory style connection.
To our knowledge, we are the only company offering the optional 3.5" connection.
Even if you did decide to go with our VS-1 or R-1 down the road, we provide an adapter that would mate our VS-1/R-1 to your DS-1 with the factory connection.
Thanks!
Jeff
      03-05-2016, 03:02 PM   #60
Rennyk.
Drives: F10 M5
Thanks for the response, I'm trying to get the best bang for my buck and it seems this might be it. The sound quality is improved in assuming? Burbles and all that?
2015 f10 M5
      03-05-2016, 03:12 PM   #61
tsims619
tsims619's Avatar
Drives: 2013 335i
Price shipped to 23462 please. Also this fit the early f30's correct? 7/13 and earlier.
      03-05-2016, 03:20 PM   #62
CG Precision
No problem. Sound quality is definitely improved. You can expect to hear some burbles
      03-05-2016, 03:21 PM   #63
Rennyk.
Drives: F10 M5
Awesome I'm hoping to order this week!
2015 f10 M5
      03-05-2016, 03:23 PM   #64
CG Precision
Awesome!
      03-05-2016, 05:36 PM   #65
Rennyk.
Drives: F10 M5
Awesome!
Put it my order now actually ?? looking forward to how this works out. I don't need to tune it with just down pipes right?
2015 f10 M5
      03-08-2016, 03:07 PM   #66
F80Boost
Drives: Beater
Any vids of this on a stock exhaust car, dp only ??
Also , any dynos of power increase with it on stock car or jb4 car ?
