BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Big Boost Custom Turbo with Built Engine ( Mods )
      05-27-2019, 10:48 PM   #23
tyler.genter
Drives: 2018 M240i
Originally Posted by hardparker View Post
What are the specs on the turbo?
Specs are a 6764 size turbo
Built B58 // instagram: tyler.genter
      05-29-2019, 04:23 PM   #24
E90ROXS
E90ROXS's Avatar
225
Drives: E90
Originally Posted by tyler.genter View Post
Here is most of the kit laid out on the table.
bro that's a messy welding job on the turbo.
      05-29-2019, 04:32 PM   #25
BPAC306
BPAC306's Avatar
Drives: M240I X
I thought the same thing... some people don't understand how this reflects on the shops quality control / workmanship....
M240i xdrive - K&N Drop in, MPE
12.3 @ 108 Stock
      05-29-2019, 05:04 PM   #26
tyler.genter
Drives: 2018 M240i
Yeah we noticed it the first day of opening and put in some work
      05-29-2019, 05:24 PM   #27
tyler.genter
Drives: 2018 M240i
Just a little update everything is apart. We replaced the pistons & rods. Ending up snapping a piston ring last week but got the pet back and are finalizing the last one!
Should have pictures of the final product from the shop soon with the heads back on
B58557.50
      05-29-2019, 05:30 PM   #28
tyler.genter
Drives: 2018 M240i
Again, please don't be afraid to speak your guys mind. I want this post zone to be a conversation started so if you see something you think could help with the build or just see something you have questions about put it on a repost. You may not be the only one thinking the same thought.
      05-30-2019, 12:24 PM   #29
E90ROXS
E90ROXS's Avatar
225
Drives: E90
How much does everything cost you? Mind if I ask...
      05-31-2019, 10:37 AM   #30
tyler.genter
Drives: 2018 M240i
Just some progress pictures.
Tonight we will have everything assembled and back together. I some how sold my wasteguage actuator with my old turbo set up so have to wait till Monday for the new one to get here. Did learn though with this kit the BMS Meth Kit Spacer is a littler nicer than the one provided by the BogBoost kit (being honest) so I will be using that one instead. Also learned a couple more things about kit.
I have plans on doing some custom work on this set up as well maybe swap some stuff, again still all in the works but besides that a very well planned kit!
kern4174449.50
      05-31-2019, 10:40 AM   #31
tyler.genter
Drives: 2018 M240i
Chill, I am trying to stay married bro haha nah but nothing really crazy as far as dollar amount goes
      05-31-2019, 11:23 AM   #32
awilki0101
awilki0101's Avatar
519
Drives: 2016 340i xDrive
I would like to see the rod bearing wear if possible. How many miles were on them?
B58557.50
      05-31-2019, 12:13 PM   #33
tyler.genter
Drives: 2018 M240i
Car has 17,8++ miles on it. Attached you should find hopefully the answer to that question. I can grab some more when I go to the shop later this weekend. All I did was blow up that last post pictures honestly just FYI
      05-31-2019, 12:17 PM   #34
tyler.genter
Drives: 2018 M240i
After comparing both stock pistons and rods to the CP set up... I have to say the Rod itself is pretty damn strong the heads on the other hand are very very thin could definitely see it being vulnerable after extreme beating
      05-31-2019, 12:59 PM   #35
E90ROXS
E90ROXS's Avatar
225
Drives: E90
According to bigboost stock engine can handle up to 600hp.
      05-31-2019, 02:01 PM   #36
tyler.genter
Drives: 2018 M240i
That's true but even Juan is working on internals now the car they use is a friend of mine's that that I have met through the bigboost company & he has confirmed that he's doing internals on his car because they car has been showing some signs of weakness
      05-31-2019, 05:39 PM   #37
awilki0101
awilki0101's Avatar
519
Thanks. From this pic its hard to see anything. Hoping to see if there was any scoring on the bearings or heat mark. It would give us an idea how they are wearing and if there is possibility of premature failure.
      05-31-2019, 06:04 PM   #38
tyler.genter
Drives: 2018 M240i
Gotcha, I'll put a reminder in my phone and grab some pictures to better assist!
      05-31-2019, 08:40 PM   #39
B58
B58's Avatar
558
Drives: 922 Turbo
Please do curious to see the damages on 0w20 oil after 17,000 miles.
2024 X3 M40i
2014 BMW M5
      06-02-2019, 02:28 PM   #40
tyler.genter
Drives: 2018 M240i
Haven't forgot just haven't been to the shop lately just wanted to keep you in the loop
      06-03-2019, 09:10 AM   #41
kern417
Cheapskate
4450
Drives: 2018 440i |2016 340i | 2010 X5
Let's be real, everyone throws out a different power figure because no one is really running the R&D. It might show that things are running well but dynoing 600hp is one thing. Beating on it for years is another. Unless they are building tearing down and rebuilding to analyze components then their feedback doesn't mean much.
I have a lot of trust in our engines based on the design but people like Tyler that will build and drive their cars will be the real testers to illustrate what the car can handle.
Youtube/Instagram/TikTok: @kern417
G.Newt810.00
      06-03-2019, 04:14 PM   #42
tyler.genter
Drives: 2018 M240i
Hope this helps brosque!! Sorry it took so long
kern4174449.50
      06-03-2019, 06:12 PM   #43
Okhan19
Jamaica
26
Drives: 328I 2015 ATM rktune downpipe
Hi what bearings are you going with? These engines usually have unique rod bearings for each engine for each rod journal (usually marked on the crankshaft of each engine). Are you going to ignore the factory recommendation and just get a standard set of high performance bearings for all rods?
      06-03-2019, 06:20 PM   #44
tyler.genter
Drives: 2018 M240i
Exactly, I plan on really getting to the bottom on this test about what these engines can really handle! Don't get me wrong it's great that these kits have great numbers on them & that's what helps promote business but the longevity of what happens when you daily these cars is the real question that we all want to know.
kern4174449.50
