BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Blue M Sport Brakes
      08-17-2016, 12:07 AM   #45
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Originally Posted by Versipellis View Post
Huh - F80 pads fit F30s? That's cool.
Yup I fitted m4 sport pads when I upgraded my fronts blue 370mm dis calipers and rotors to match the existing rear blue m sport 345mm dis rotors.
http://f30.bimmerpost.com/forums/sho...2&postcount=42
TBH 340/345 m sport with SS lines, decent pads and RBF or dot 5.1 BF is a very effective upgrade.
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      08-17-2016, 12:41 AM   #46
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Originally Posted by Dmitry83 View Post
The calipers for 370mm and 340mm rotors are different due to 15mm difference in mounting holes position to carry 30mm bigger diameter rotor.
The pads are interchangable as the rotor working surface has equal width (say pad path)- the diameter is bigger so is the brake force arm, the contact area is the same.
Photo below shows the subtle difference between 340mm caliper (top) and 370/380mm caliper
Taken from this 2addicts thread
http://www.2addicts.com/forums/showt...0%2F380&page=2
      03-13-2017, 04:11 PM   #47
Cammy5
Drives: 2016 BMW 328i M Sport 6MT
The M Sport $650 brake upgrade is very similar to the $2K plus M Performance Brake Upgrade as they both have (made by Brembo for BMW) 4 piston front calipers and 2 piston rear calipers. They actually have the same sized rotors as well - 370mm front, 345mm rear. The only difference are caliper color (blue vs a choice of red, yellow, or orange) and blank rotors vs dimpled and slotted.
In my head, if you are building a car to spec the $650 M Sport brake option is an absolute no brainer. If you buy one off the lot that didn't have that option, the M Perf Brake upgrade is for you, albeit more expensive.
2016 BMW 328i M Sport 6MT (Mineral Grey over Coral Red)
*BPC DME Custom Stage 1 Tune
*Evolution Racerwerks Competition Intercooler & Chargepipe
*M Performance Big Brake Kit
      06-26-2017, 11:48 PM   #48
BlueLeaderXI
Drives: 2021 Portimao Blue M340i xDriv
I love these and have always wanted the blue calipers. (NOT the M perf orange/yellow/red).
Working on upgrading my newly purchased 2015 Melbourne Red 335i XDrive with an M Perf Exhaust- then will be on the lookout for front/rear BLUE m sport calipers.
If anyone knows anyone selling 4 blue calipers, let me know.
      07-27-2017, 08:07 AM   #49
BlueLeaderXI
OK, quick Q:
Summary: 2 versions of M Sport Blue Brake kit&calipers- one for 340mm on f20's, one for 370mm on f30's. Got it.
Has anyone upgraded their stock 335i rotors (340mm)with the F20 BLUE M Sport calipers? (#34116799465 & 466)
As mentioned above, a 340mm/345mm setup is plenty fine. Pads will change the practical feel more anyway. I'm not leaping forward in performance here over the stock 335i, however, I like M Sport BLUE @ all 4 corners while somewhat minimizing the cost. If the M Sport Blue calipers meant for the F20 are plug & play to my 340mm rotors on my stock 335i, I'd consider that.
(Although, both versions of M Sport Blue Calipers appear to be the same price.. I'd really just circumvent paying for larger rotors and mounting hardware, but still pay for overhauling the rears. I get it).
      07-27-2017, 11:00 AM   #50
Dmitry83
Russian Federation
54
Drives: F30 320i (328i ECU) M-Sport
Originally Posted by Drsr1588 View Post
OK, quick Q:
Same 340mm front blue are on 320i and lower.
For 335i you should change the front pads for something with more bite- either 460 OEM "Sport" pads, or 969 "M3" pads, or some Hawk HPS, EBC Yellow or similar.
I had 066 base pads with the grey 335i front I've put first, and those are terribly slippery.
I've fed up with hot squeal (better to say SCREAM!) of EBC Yellow on the stock 300mm rears, so decided to give the factory 460's a try instead of any analogues.
'13 F30 320i (328i ECU) RWD M-Sport
Michelin PSS, M-Sport brakes, 320i LCI muffler
F32 bottom V-bar
F80 bottom reinforcement plate
Koni Sport, M-Performance springs, M135i Anti-roll bars
      07-28-2017, 08:33 AM   #51
BlueLeaderXI
Would the F20 BLUE M Sport Caliper version (for 340mm) fit my current rotors? Has anyone done this? Or should I just accept the fact that I'll be paying to retrofit 4 blue calipers and diff rotors as well?
      07-28-2017, 09:06 AM   #52
Dmitry83
Russian Federation
54
The rotors are equal 340x30mm, blank (not drilled/slotted).
So you just replace the front calipers with the blue ones to match the rears.
F32 bottom V-bar
      10-20-2017, 12:25 PM   #53
Kailec
Kailec's Avatar
Drives: 2013 328i xDrive
Originally Posted by oceanview View Post
As every other BMW part, they also have a part number and can be ordered as "repair" part. Just because it's not factory installed doesn't mean you can't order that and have that installed.
The Blue once for the 328i should be:
Left front = 34 11 6 799 469
Right front = 34 11 6 799 470
Left back = 34 21 6 799 461
Right back = 34 21 6 799 462
(as far as I could see)
Natrurally additional other parts are needed. But your dealer would know.
Sorry to revive a dead thread but I would like the blues for my 328i xDrive. Are these the 4 part numbers I should be asking my dealer about? What sized rotors would I need to accommodate these calipers, is it 370 all around?
      10-20-2017, 01:04 PM   #54
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
You need BMW part no 34-11-2-221-445 brake (kit) (this is the entire kit minus the rear rotors). Rotor spec is 34206797600.
You will need to specify blue colour. You may have some challenges ordering this in Toronto if you're trying to use that part number though. This kit number seems to be more commonly known in the US. You're also going to pay an arm and a leg.
2016 BMW F80 ZCP
Instagram : 7IM3LESS
https://instagram.com/7im3less?igshid=YmMyMTA2M2Y=
      10-20-2017, 01:39 PM   #55
FaRKle!
You can use realoem to find the PNs for the M Sport brakes for your car.
Note, that you can also use the M sport calipers/rotors from a 335/340. Don't use rear axle parts from the 328i (has a smaller rear hub than your x-drive car).
      10-20-2017, 03:47 PM   #56
Kailec
Kailec's Avatar
Those are for the M Performance ones that you have though, no? I've asked the dealership before and they said that they only sell it in red, yellow and orange.
      10-21-2017, 03:20 PM   #57
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
The rear rotor of the Blue, Red, Orange, Yellow is always 345mm
If you want 370mm rotors in front, those where the part numbers for the front calipers. (and the rears).
Both in blue.
As I saw in realoem.com the are superseeded by new part numbers. But your dealer can check and see the correct numbers.
As the 18" M Performance Brake Kit is only available in yellow, red, orange you shouldn't order the kit.
But you can order everything as single replacement part.
The blue calipers for the 370mm front rotor can be ordered as such replacement parts.
For example the 335i get's the 370mm rotor and the blue caliper when buying the option "S2NHA".
The following link shows the 335i front caliper part number with "S2NHA"=YES (so the calipers must come in blue)
http://www.realoem.com/bmw/enUS/show...diagId=34_2012
(I did choose the 335iX USA version, because the 328i USA Version will get 340mm front rotor with the "S2NHA" option. And so the blue calipers will only fit for the 340mm rotor but not for the 370mm rotor)
For the rear caliper:
The rear rotor with the "S2NHA" option will always be 345mm size. So the same blue caliper is used for the whole F3x series with "S2NHA" option
http://www.realoem.com/bmw/enUS/show...diagId=34_2033
For the front rotors: Any 370mm rotor flat surface or dimpled/slotted version is fine
For the rear rotors: 345mm rotor come in different flavors depending on the emergency brake size. So you dealer needs to order the right one for your car.
I belive
34206797607 normal flat surface
or
34206797600 dimpled/slotted surface
are those for your car.
http://www.realoem.com/bmw/enUS/show...diagId=34_1970
Hope this helps
Kailec594.50
      10-21-2017, 04:06 PM   #58
Kailec
Kailec's Avatar
Both in blue.
I belive
or
Hope this helps
Yes this helped a lot! Just some quick additional questions. Based on:
http://www.realoem.com/bmw/enUS/show...diagId=34_1949
It looks like front should be 340mm for me then, and 345mm in the back?
Since I've never bothered to change rotors before, is there any difference in OEM vs aftermarket ones?
Thanks!
      10-21-2017, 04:24 PM   #59
oceanview
oceanview's Avatar
Switzerland
207
Well, you can choose between 370mm or 340mm front rotor. (The M Performance Brakes option is 370/345 for all F3x from 316 to 340).
By choosing 370mm rotor, 18" rims are needed. Summer and Winter!
Snow chains won't fit on 18" wheels. (If I'm not wrong)
And again, depending on the front rotor size, the front blue caliper have different part numbers.
Braking power is about the same for 340/345 and 370/345. The larger rotor just looks way better with 19" or 20" rims.
      10-21-2017, 04:30 PM   #60
Kailec
Kailec's Avatar
Ah okay. Well I've got 18" and don't plan to ever change that. Would 340mm look too small? Also when I look at:
I don't see 370mm listed?
      10-22-2017, 04:24 AM   #61
oceanview
oceanview's Avatar
Switzerland
207
Kailec
1. No 340mm don't look to small on 18" rims, but kind of with 20". (340mm rotor btw, the factory rotor size for some F3x like the 335i.)
2. Not all 18" rims will work with 370mm rotor and the according caliper.
Here is a list of all BMW rims, that are fine with the 370mm rotor.
If you have any aftermarket 18" rims, you need to check if they free the caliper if using the 370mm rotor.
http://www.realoem.com/bmw/enUS/show...diagId=03_0108
3. You don't see that listed because the US version 328i S2NHA option only upgrades to 340mm rotor and the "small" blue caliper in front. (In Canada you get the US version as well, I think. Check with your VIN Code)
Every F3x will get 370mm and "big" caliper, with the M Performance Brake (red, yellow, orange)
Every F3x 335i/340i will get 370mm and "big" caliper with the S2NHA Option (blue caliper)
On every F3x you can, from a technical point of view, mount the "big" blue S2NHA caliper of an 335i/340i.
If you want "big" blue caliper and 370mm front rotor, just look at the front part of the 335i/340i. S2NHA=YES
If you want "small" blue caliper and 340mm front rotor, just look at the front part of the US model 328i. S2NHA=YES
For the rear parts take exactly the one of the S2NHA for YOUR car (because of the rear brake rotor can vary due to emergency brake differences of F3x models)
Perhaps you also look at my F3x brake thread.
http://f30.bimmerpost.com/forums/sho...d.php?t=858607
7iM3less2595.00
      10-22-2017, 07:59 AM   #62
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
Kailec
Here's a photo of the 400m 18" rim with 370 rotor. There is literally zero room in between.
I can barely fit my finger in between.
2016 BMW F80 ZCP
      10-22-2017, 09:26 PM   #63
Kailec
Kailec's Avatar
Kailec
Thanks for the info, I'll have a chat with the dealership some time soon about it all to get a ballpark figure.
      10-22-2017, 09:27 PM   #64
Kailec
Kailec's Avatar
I love how big it is and easy to see. Do you notice a huge difference in braking?
      10-23-2017, 08:38 AM   #65
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
I don't really notice "much" of a braking difference. The bigger impact was aesthetics.
If you ask me - if the new look is worth the price than go for it otherwise the money's not really worth the performance difference. Just me though.
2016 BMW F80 ZCP
      10-23-2017, 09:20 AM   #66
Kailec
Kailec's Avatar
Ah okay. Still my brakes (especially the calipers) really stand out in a bad way. I'll definitely upgrade but I'll wait til my current rotors need it.
blue, brakes, caliper, f30, msport
