BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DRL always on
proTUNING Freaks
      11-14-2020, 01:58 AM   #23
Gregoire102
Drives: BMW F30
Info
Hi steve498 can you provide wiring details please mate? same issue.
      11-24-2020, 09:02 AM   #24
svintit
Drives: BMW F30
Blinkers for DRL and normal running lights
Hi there, curious if you ever got this working? I have a similar question.
I can't seem to find the exact answer to this. Seems Bimmercode has the option for either the blinkers to be on for DRL or normal running lights, i'd like to have them for both.
Also alongside this, i'd like the mirror blinkers to do the same.
Basically right now I have the front headlight blinkers and mirror blinkers on with normal lights and they work perfectly, I just need to enable them for DRL's also.
I think I have FEM_BODY and have coded the mirrors blinkers to be on in expert settings following some other thread.
      07-17-2021, 10:52 AM   #25
Islamaal
Drives: F30
Any update on wire diagram, and whats the diode
Originally Posted by steve498 View Post
No unfortunately it's a wiring job. I've now adjusted the car's wiring loom and depos work perfect. You need to cut the DRL cable which is powered when the car's sidelights is turned on (it dimms the drls) and the low beam cable. Then a diode between them so when the low beam is on, it powers the side light cable and when the side light is on, power isn't sent to the low beam. It's a simple job and took me a few weeks of making diagrams to make sure I got it right but all works fine now
      07-17-2021, 10:53 AM   #26
Islamaal
Drives: F30
Hi
Any update about wire diagram
      02-20-2022, 03:40 AM   #27
54VAGE
Drives: '09 E92 N54 335i
2009 BMW 335i  [0.00]
can i get the info on the wires/diagram if you remember, i wanna do this too lol
E92 N54
JB4, MHD, Alpina flash, ARM DPs, Cobb CP/HKS bov, BMS DCI/OCV, PE exhaust, 2nd cat delete (vibrant 1792), Mishimoto FMIC, Fuel-It stage 2, Msport
F30 N20 EWG
      02-26-2022, 04:09 PM   #28
Keewee
Keewee's Avatar
New Zealand
Drives: BMW F30 328, BMW F10 550
2012 550i  [0.00]
2012 328i  [0.00]
Hi, I used Carly & you can it what switch positions to be on. By default I believe the off position.
